Deadlock found when trying to get lock
Переодически вылетает такая ошибка: авторSQLSTATE[40001]: Serialization failure: 1213 Deadlock found when trying to get lock; try restarting transaction\nThe SQL being executed was: INSERT INTO `worker_parameter_value` (`worker_parameter_id`, `date_time`, `value`, `status_id`, `shift`, `date_work`) VALUES ('182252', '2020-11-6 12:21:9.835778', '17330.35,-803.14,-14317.85', 1, 1, '2020-11-06'), ('195206', '2020-11-6 12:21:9.835778', '212354', 16, 1, '2020-11-06'), ('195194', '2020-11-6 12:21:9.835778', 349196, 1, 1, '2020-11-06'), ('195482', '2020-11-6 12:21:9.835778', 0, 45, 1, '2020-11-06'), ('195488', '2020-11-6 12:21:9.835778', 0, 1, 1, '2020-11-06') ON DUPLICATE KEY UPDATE `value` = VALUES (`value`), `status_id` = VALUES (`status_id`), `shift` = VALUES (`shift`), `date_work` = VALUES (`date_work`) Кто нибудь сталкивался с подобным? ... |
| 06.11.2020, 12:30 |
start [/forum/topic.php?fid=47&gotonew=1&tid=1828321]: |
144ms |
35ms |
| others: | 221ms |
| total: | 436ms |
