Помогите переписать запрос с postgreSQL на mySQL
собственно сам запрос WITH RECURSIVE category_tree(id, name, depth) AS ( SELECT id, "sCaption", ARRAY[id] FROM "BGT_Item" WHERE "idParent" IS NULL UNION ALL SELECT "BGT_Item".id, "BGT_Item"."sCaption", depth || "BGT_Item".id FROM category_tree JOIN "BGT_Item" ON "BGT_Item"."idParent"=category_tree.id WHERE NOT "BGT_Item".id = ANY(depth) ) SELECT name,array_length(depth,1) as depth FROM category_tree ORDER BY id; ... |
| 30.01.2021, 12:14 |
Код: sql 1. 2. 3. 4. 5. 6. 7. 8. ... |
| 30.01.2021, 13:07 |
start [/forum/topic.php?fid=47&gotonew=1&tid=1828210]: |
29ms |
27ms |
| others: | 207ms |
| total: | 316ms |
