Запрос вызывает ошибку #1064
Код: sql 1. 2. 3. 4. Запрос вызывает ошибку #1064 - You have an error in your SQL syntax; check the manual that corresponds to your MariaDB server version for the right syntax to use near 'where not exists (select * from languages where country_id = (select id from ...' at line 1 ... |
| 07.04.2021, 07:06:56 |
Код: sql 1. 2. 3. 4. 5. 6. 7. 8. ... |
| 07.04.2021, 17:06:32 |
ну и для MySQL тоже неоднозначно fiddle ... |
| 08.04.2021, 02:35:05 |
start [/forum/topic.php?fid=47&gotonew=1&tid=1828115]: |
217ms |
31ms |
| others: | 200ms |
| total: | 486ms |
