помогите решить задания, есть таблица нужно выполнить sql запросы (задания внизу)
# создание таблиц CREATE DATABASE IF NOT EXISTS study_database; USE study_database; # создание таблиц CREATE TABLE brands ( id int(11) NOT NULL AUTO_INCREMENT, brand varchar(45) NOT NULL, PRIMARY KEY (id) ) ENGINE=InnoDB AUTO_INCREMENT=1 DEFAULT CHARSET=utf8; CREATE TABLE categories ( id int(11) NOT NULL AUTO_INCREMENT, category varchar(45) NOT NULL DEFAULT 'name category', description varchar(100) DEFAULT NULL, PRIMARY KEY (id), UNIQUE KEY category_UNIQUE (category) ) ENGINE=InnoDB AUTO_INCREMENT=1 DEFAULT CHARSET=utf8; CREATE TABLE suppliers ( id INT NOT NULL AUTO_INCREMENT, supplier VARCHAR(50) NOT NULL, address VARCHAR(50), contacts VARCHAR(50), PRIMARY KEY (id) ) ENGINE=InnoDB AUTO_INCREMENT=1 DEFAULT CHARSET=utf8; CREATE TABLE products ( id int(11) NOT NULL AUTO_INCREMENT, category_id int(11) NOT NULL, brand_id int(11) DEFAULT NULL, product varchar(45) NOT NULL, price decimal(10,2) DEFAULT '0.00', description varchar(100) DEFAULT NULL, PRIMARY KEY (id), KEY FK_category_idx (category_id), KEY FK_brand_idx (brand_id), CONSTRAINT FK_brand FOREIGN KEY (brand_id) REFERENCES brands (id) ON UPDATE CASCADE, CONSTRAINT FK_category FOREIGN KEY (category_id) REFERENCES categories (id) ON UPDATE CASCADE ) ENGINE=InnoDB AUTO_INCREMENT=1 DEFAULT CHARSET=utf8; CREATE TABLE actions ( id int(11) NOT NULL AUTO_INCREMENT, action_date datetime NOT NULL, product_id int(11) NOT NULL, supplier_id int(11) NOT NULL, qty decimal(10,3) NOT NULL DEFAULT '0.000', price decimal(10,2) NOT NULL DEFAULT '0.00', PRIMARY KEY (id), INDEX FK_product_idx (product_id), CONSTRAINT FK_product FOREIGN KEY (product_id) REFERENCES products (id), CONSTRAINT FK_supplier FOREIGN KEY (supplier_id) REFERENCES suppliers (id) ) ENGINE=InnoDB AUTO_INCREMENT=1 DEFAULT CHARSET=utf8; # Вставка категорий товаров INSERT INTO categories (category, description) VALUES ('HDD', 'Жесткие диски'); INSERT INTO categories (category, description) VALUES ('Monitors', 'Мониторы'); INSERT INTO categories (category, description) VALUES ('Motherboards', 'Материнские платы'); INSERT INTO categories (category, description) VALUES ('DDR', 'Оперативная память'); #INSERT INTO categories (category, description) VALUES ('Smartphones', 'Смартфоны'); # Вставка брендов INSERT INTO brands (brand) VALUES ('Samsung'); INSERT INTO brands (brand) VALUES ('ASUS'); INSERT INTO brands (brand) VALUES ('Acer'); # Вставка поставщиков INSERT INTO suppliers (supplier, address, contacts) VALUES ('Silk Road','Shanghai 6-7/115','mr.Lee p:234-177-123-456-6'); INSERT INTO suppliers (supplier, address, contacts) VALUES ('Cargo Transfer','Shanghai, Mao av. 899-1201', Null); INSERT INTO suppliers (supplier, address, contacts) VALUES ('4U','Urumchi',''); INSERT INTO suppliers (supplier, address, contacts) VALUES ('IDT','Beijing',''); # Вставка товара 1 INSERT INTO products (category_id, brand_id, product, price, description) VALUES ((SELECT id FROM categories where category='HDD'), (SELECT id FROM brands where brand='Samsung'), 'S1 HDD 1T, 7200 rpm', 125, ''); # Вставка товара 2 INSERT INTO products (category_id, brand_id, product, price, description) VALUES ((SELECT id FROM categories where category='HDD'), (SELECT id FROM brands where brand='Samsung'), 'S2 HDD 500Gb, 7200 rpm', 85, ''); # Вставка товара 3 INSERT INTO products (category_id, brand_id, product, price, description) VALUES ((SELECT id FROM categories where category='HDD'), (SELECT id FROM brands where brand='Samsung'), 'S3 HDD 250Gb, 10000 rpm', 150, ''); # Вставка товара 4 INSERT INTO products (category_id, brand_id, product, price, description) VALUES ((SELECT id FROM categories where category='HDD'), (SELECT id FROM brands where brand='Samsung'), 'S4 HDD 1T, 7200rpm', 127, ''); # Вставка товара 5 INSERT INTO products (category_id, brand_id, product, price, description) VALUES ((SELECT id FROM categories where category='HDD'), (SELECT id FROM brands where brand='Samsung'), 'S5 HDD 500Gb, 7200rpm', 92, ''); # Вставка товара 6 INSERT INTO products (category_id, brand_id, product, price, description) VALUES ((SELECT id FROM categories where category='HDD'), (SELECT id FROM brands where brand='Acer'), 'Z1 HDD 750Gb, 72000rpm', 100, ''); # Вставка товара 7 INSERT INTO products (category_id, brand_id, product, price, description) VALUES ((SELECT id FROM categories where category='HDD'), (SELECT id FROM brands where brand='Acer'), 'Z2 HDD 750Gb, 72000rpm', 110, ''); # Вставка товара 8 INSERT INTO products (category_id, brand_id, product, price, description) VALUES ((SELECT id FROM categories where category='HDD'), NULL, 'UN1 HDD 750Gb, 72000rpm', 105, ''); # Вставка товара 9 INSERT INTO products (category_id, brand_id, product, price, description) VALUES ((SELECT id FROM categories where category='Monitors'), (SELECT id FROM brands where brand='Samsung'), 'Monitor B19', 135, ''); # Вставка товара 10 INSERT INTO products (category_id, brand_id, product, price, description) VALUES ((SELECT id FROM categories where category='Monitors'), (SELECT id FROM brands where brand='Samsung'), 'Monitor B22', 170, ''); # Вставка товара 11 INSERT INTO products (category_id, brand_id, product, price, description) VALUES ((SELECT id FROM categories where category='Monitors'), (SELECT id FROM brands where brand='Samsung'), 'Monitor B25', 320, ''); # Вставка товара 12 INSERT INTO products (category_id, brand_id, product, price, description) VALUES ((SELECT id FROM categories where category='Monitors'), (SELECT id FROM brands where brand='Acer'), 'Monitor A20', 150, ''); # Вставка товара 13 INSERT INTO products (category_id, brand_id, product, price, description) VALUES ((SELECT id FROM categories where category='Monitors'), (SELECT id FROM brands where brand='Acer'), 'Monitor A21', 170, ''); # Вставка товара 14 INSERT INTO products (category_id, brand_id, product, price, description) VALUES ((SELECT id FROM categories where category='Monitors'), (SELECT id FROM brands where brand='ASUS'), 'Monitor DD27', 370, ''); # Вставка товара 15 INSERT INTO products (category_id, brand_id, product, price, description) VALUES ((SELECT id FROM categories where category='DDR'), (SELECT id FROM brands where brand='Samsung'), 'DDR3 SST 2Gb', 25, ''); # Вставка товара 16 INSERT INTO products (category_id, brand_id, product, price, description) VALUES ((SELECT id FROM categories where category='DDR'), (SELECT id FROM brands where brand='Samsung'), 'DDR3 SST 4Gb', 42, ''); # Вставка товара 17 INSERT INTO products (category_id, brand_id, product, price, description) VALUES ((SELECT id FROM categories where category='DDR'), (SELECT id FROM brands where brand='ASUS'), 'DDR3 BTT 4Gb', 48, ''); # Вставка товара 18 INSERT INTO products (category_id, brand_id, product, price, description) VALUES ((SELECT id FROM categories where category='DDR'), (SELECT id FROM brands where brand='ASUS'), 'DDR3 BTT 8Gb', 90, ''); # Вставка товара 19 INSERT INTO products (category_id, brand_id, product, price, description) VALUES ((SELECT id FROM categories where category='DDR'), (SELECT id FROM brands where brand='ASUS'), 'DDR3 ZPP 4Gb', 45, ''); # Вставка товара 20 INSERT INTO products (category_id, brand_id, product, price, description) VALUES ((SELECT id FROM categories where category='DDR'), NULL,'DDR3 UNK 2Gb', 24, ''); # Вставка товара 21 INSERT INTO products (category_id, brand_id, product, price, description) VALUES ((SELECT id FROM categories where category='DDR'), NULL,'DDR2 UNK 1Gb', 17, ''); # Вставка товара 22 INSERT INTO products (category_id, brand_id, product, price, description) VALUES ((SELECT id FROM categories where category='Motherboards'), (SELECT id FROM brands where brand='Samsung'), 'MB-1', 75, ''); # Вставка товара 23 INSERT INTO products (category_id, brand_id, product, price, description) VALUES ((SELECT id FROM categories where category='Motherboards'), (SELECT id FROM brands where brand='Samsung'), 'MB-2', 76, ''); # Вставка товара 24 INSERT INTO products (category_id, brand_id, product, price, description) VALUES ((SELECT id FROM categories where category='Motherboards'), (SELECT id FROM brands where brand='ASUS'), 'MB-3', 80, ''); # Вставка товара 25 INSERT INTO products (category_id, brand_id, product, price, description) VALUES ((SELECT id FROM categories where category='Motherboards'), (SELECT id FROM brands where brand='ASUS'), 'MB-4', 95, ''); # Вставка товара 26 INSERT INTO products (category_id, brand_id, product, price, description) VALUES ((SELECT id FROM categories where category='Motherboards'), (SELECT id FROM brands where brand='ASUS'), 'MB-5', 160, ''); # Вставка товара 27 INSERT INTO products (category_id, brand_id, product, price, description) VALUES ((SELECT id FROM categories where category='Motherboards'), (SELECT id FROM brands where brand='Acer'), 'MB-6', 180, ''); # Вставка товара 28 INSERT INTO products (category_id, brand_id, product, price, description) VALUES ((SELECT id FROM categories where category='Motherboards'), (SELECT id FROM brands where brand='Acer'), 'MB-7', 200, ''); # Вставка товара 29 INSERT INTO products (category_id, brand_id, product, price, description) VALUES ((SELECT id FROM categories where category='Motherboards'), NULL, 'MB-8', 250, ''); # Silk Road #Вставка поступлений товара actions 1 INSERT INTO actions (action_date, product_id, supplier_id, qty, price) VALUES ('2015-07-25 12:30:33', (select id from products where product='S3 HDD 250Gb, 10000 rpm'), # product (select id from suppliers where supplier='Silk Road'), # supplier 100, # qty 110); #Вставка поступлений товара actions 2 INSERT INTO actions (action_date, product_id, supplier_id, qty, price) VALUES ('2015-07-25 12:30:33', (select id from products where product='S5 HDD 500Gb, 7200rpm'), # product (select id from suppliers where supplier='Silk Road'), # supplier 80, # qty 95); #Вставка поступлений товара actions 3 INSERT INTO actions (action_date, product_id, supplier_id, qty, price) VALUES ('2015-07-25 12:30:33', (select id from products where product='UN1 HDD 750Gb, 72000rpm'), # product (select id from suppliers where supplier='Silk Road'), # supplier 48, # qty 84); #Вставка поступлений товара actions 4 INSERT INTO actions (action_date, product_id, supplier_id, qty, price) VALUES ('2015-07-25 12:30:33', (select id from products where product='Monitor B25'), # product (select id from suppliers where supplier='Silk Road'), # supplier 16, # qty 340); #Вставка поступлений товара actions 5 INSERT INTO actions (action_date, product_id, supplier_id, qty, price) VALUES ('2015-07-30 09:30:00', (select id from products where product='Monitor B25'), # product (select id from suppliers where supplier='Silk Road'), # supplier 10, # qty 345); #Вставка поступлений товара actions 6 INSERT INTO actions (action_date, product_id, supplier_id, qty, price) VALUES ('2015-07-30 09:30:00', (select id from products where product='DDR3 SST 2Gb'), # product (select id from suppliers where supplier='Silk Road'), # supplier 50, # qty 40); #Вставка поступлений товара actions 7 INSERT INTO actions (action_date, product_id, supplier_id, qty, price) VALUES ('2015-07-30 09:30:00', (select id from products where product='DDR3 SST 4Gb'), # product (select id from suppliers where supplier='Silk Road'), # supplier 40, # qty 55); #Вставка поступлений товара actions 8 INSERT INTO actions (action_date, product_id, supplier_id, qty, price) VALUES ('2015-08-14 15:30:00', (select id from products where product='DDR3 BTT 4Gb'), # product (select id from suppliers where supplier='Silk Road'), # supplier 50, # qty 60); #Вставка поступлений товара actions 9 INSERT INTO actions (action_date, product_id, supplier_id, qty, price) VALUES ('2015-08-14 15:30:00', (select id from products where product='S5 HDD 500Gb, 7200rpm'), # product (select id from suppliers where supplier='Silk Road'), # supplier 50, # qty 98); #Вставка поступлений товара actions 10 INSERT INTO actions (action_date, product_id, supplier_id, qty, price) VALUES ('2015-08-20 10:05:00', (select id from products where product='Monitor DD27'), # product (select id from suppliers where supplier='Silk Road'), # supplier 10, # qty 330); #13.02.2017 #Вставка поступлений товара actions 11 INSERT INTO actions (action_date, product_id, supplier_id, qty, price) VALUES ('2015-08-25 12:15:00', (select id from products where product='S3 HDD 250Gb, 10000 rpm'), # product (select id from suppliers where supplier='Silk Road'), # supplier 50, # qty 115); #Вставка поступлений товара actions 12 INSERT INTO actions (action_date, product_id, supplier_id, qty, price) VALUES ('2015-08-25 12:15:00', (select id from products where product='DDR3 BTT 4Gb'), # product (select id from suppliers where supplier='Silk Road'), # supplier 15, # qty 86); #Вставка поступлений товара actions 13 INSERT INTO actions (action_date, product_id, supplier_id, qty, price) VALUES ('2015-08-25 12:15:00', (select id from products where product='S4 HDD 1T, 7200rpm'), # product (select id from suppliers where supplier='Silk Road'), # supplier 25, # qty 117); #Вставка поступлений товара actions 14 INSERT INTO actions (action_date, product_id, supplier_id, qty, price) VALUES ('2015-08-25 14:33:00', (select id from products where product='S4 HDD 1T, 7200rpm'), # product (select id from suppliers where supplier='Silk Road'), # supplier 25, # qty 117); #Вставка поступлений товара actions 15 INSERT INTO actions (action_date, product_id, supplier_id, qty, price) VALUES ('2015-10-04 12:50:00', (select id from products where product='S1 HDD 1T, 7200 rpm'), # product (select id from suppliers where supplier='Silk Road'), # supplier 30, # qty 121); #Вставка поступлений товара actions 16 INSERT INTO actions (action_date, product_id, supplier_id, qty, price) VALUES ('2015-10-27 09:18:00', (select id from products where product='S4 HDD 1T, 7200rpm'), # product (select id from suppliers where supplier='Silk Road'), # supplier 5, # qty 125); #Вставка поступлений товара actions 17 INSERT INTO actions (action_date, product_id, supplier_id, qty, price) VALUES ('2015-12-11 09:20:00', (select id from products where product='S3 HDD 250Gb, 10000 rpm'), # product (select id from suppliers where supplier='Silk Road'), # supplier 10, # qty 143); #Вставка поступлений товара actions 18 INSERT INTO actions (action_date, product_id, supplier_id, qty, price) VALUES ('2016-02-07 09:43:00', (select id from products where product='DDR3 BTT 4Gb'), # product (select id from suppliers where supplier='Silk Road'), # supplier 51, # qty 43); #Вставка поступлений товара actions 19 INSERT INTO actions (action_date, product_id, supplier_id, qty, price) VALUES ('2016-03-12 09:21:00', (select id from products where product='DDR3 SST 2Gb'), # product (select id from suppliers where supplier='Silk Road'), # supplier 70, # qty 18); #Вставка поступлений товара actions 20 INSERT INTO actions (action_date, product_id, supplier_id, qty, price) VALUES ('2016-06-28 08:55:00', (select id from products where product='DDR3 SST 4Gb'), # product (select id from suppliers where supplier='Silk Road'), # supplier 35, # qty 36); #Вставка поступлений товара actions 21 INSERT INTO actions (action_date, product_id, supplier_id, qty, price) VALUES ('2016-07-15 10:02:00', (select id from products where product='Monitor A20'), # product (select id from suppliers where supplier='Silk Road'), # supplier 20, # qty 135); #Вставка поступлений товара actions 22 INSERT INTO actions (action_date, product_id, supplier_id, qty, price) VALUES ('2016-07-16 09:57:00', (select id from products where product='S1 HDD 1T, 7200 rpm'), # product (select id from suppliers where supplier='Silk Road'), # supplier 45, # qty 116); #Вставка поступлений товара actions 23 INSERT INTO actions (action_date, product_id, supplier_id, qty, price) VALUES ('2016-09-15 09:15:00', (select id from products where product='Monitor A20'), # product (select id from suppliers where supplier='Silk Road'), # supplier 5, # qty 142); #Вставка поступлений товара actions 24 INSERT INTO actions (action_date, product_id, supplier_id, qty, price) VALUES ('2016-09-20 10:03:00', (select id from products where product='S2 HDD 500Gb, 7200 rpm'), # product (select id from suppliers where supplier='Silk Road'), # supplier 13, # qty 74); #Вставка поступлений товара actions 25 INSERT INTO actions (action_date, product_id, supplier_id, qty, price) VALUES ('2016-10-02 11:10:00', (select id from products where product='Monitor B19'), # product (select id from suppliers where supplier='Silk Road'), # supplier 24, # qty 121); #Вставка поступлений товара actions 26 INSERT INTO actions (action_date, product_id, supplier_id, qty, price) VALUES ('2016-10-23 10:02:00', (select id from products where product='DDR3 BTT 8Gb'), # product (select id from suppliers where supplier='Silk Road'), # supplier 55, # qty 79); #Вставка поступлений товара actions 27 INSERT INTO actions (action_date, product_id, supplier_id, qty, price) VALUES ('2016-10-23 10:03:00', (select id from products where product='Monitor B25'), # product (select id from suppliers where supplier='Silk Road'), # supplier 6, # qty 295); #Вставка поступлений товара actions 28 INSERT INTO actions (action_date, product_id, supplier_id, qty, price) VALUES ('2016-10-23 10:04:00', (select id from products where product='S4 HDD 1T, 7200rpm'), # product (select id from suppliers where supplier='Silk Road'), # supplier 100, # qty 108); #Вставка поступлений товара actions 29 INSERT INTO actions (action_date, product_id, supplier_id, qty, price) VALUES ('2016-11-11 09:44:00', (select id from products where product='DDR3 ZPP 4Gb'), # product (select id from suppliers where supplier='Silk Road'), # supplier 75, # qty 31); #Вставка поступлений товара actions 30 INSERT INTO actions (action_date, product_id, supplier_id, qty, price) VALUES ('2016-12-17 11:00:00', (select id from products where product='DDR3 BTT 8Gb'), # product (select id from suppliers where supplier='Silk Road'), # supplier 20, # qty 77); #Вставка поступлений товара actions 31 INSERT INTO actions (action_date, product_id, supplier_id, qty, price) VALUES ('2016-12-20 08:50:00', (select id from products where product='DDR3 BTT 4Gb'), # product (select id from suppliers where supplier='Silk Road'), # supplier 12, # qty 40); #Вставка поступлений товара actions 32 INSERT INTO actions (action_date, product_id, supplier_id, qty, price) VALUES ('2017-01-12 11:01:00', (select id from products where product='Monitor DD27'), # product (select id from suppliers where supplier='Silk Road'), # supplier 10, # qty 340); #Вставка поступлений товара actions 33 INSERT INTO actions (action_date, product_id, supplier_id, qty, price) VALUES ('2017-01-12 11:02:00', (select id from products where product='DDR3 BTT 8Gb'), # product (select id from suppliers where supplier='Silk Road'), # supplier 25, # qty 76); #Вставка поступлений товара actions 34 INSERT INTO actions (action_date, product_id, supplier_id, qty, price) VALUES ('2017-01-12 11:03:00 ', (select id from products where product='S1 HDD 1T, 7200 rpm'), # product (select id from suppliers where supplier='Silk Road'), # supplier 37, # qty 115); #Вставка поступлений товара actions 35 INSERT INTO actions (action_date, product_id, supplier_id, qty, price) VALUES ('2017-02-25 13:50:00', (select id from products where product='S3 HDD 250Gb, 10000 rpm'), # product (select id from suppliers where supplier='Silk Road'), # supplier 50, # qty 128); #Вставка поступлений товара actions 36 INSERT INTO actions (action_date, product_id, supplier_id, qty, price) VALUES ('2017-02-26 09:30:00', (select id from products where product='Monitor B25'), # product (select id from suppliers where supplier='Silk Road'), # supplier 19, # qty 302); #Вставка поступлений товара actions 37 INSERT INTO actions (action_date, product_id, supplier_id, qty, price) VALUES ('2017-02-27 09:36:00', (select id from products where product='S4 HDD 1T, 7200rpm'), # product (select id from suppliers where supplier='Silk Road'), # supplier 11, # qty 119); #Вставка поступлений товара actions 38 INSERT INTO actions (action_date, product_id, supplier_id, qty, price) VALUES ('2017-03-02 09:44:00', (select id from products where product='S5 HDD 500Gb, 7200rpm'), # product (select id from suppliers where supplier='Silk Road'), # supplier 40, # qty 80); #Cargo Transfer #Вставка поступлений товара actions 39 INSERT INTO actions (action_date, product_id, supplier_id, qty, price) VALUES ('2015-07-26 08:30:00', (select id from products where product='MB-1'), # product (select id from suppliers where supplier='Cargo Transfer'), # supplier 25, # qty 76); #Вставка поступлений товара actions 40 INSERT INTO actions (action_date, product_id, supplier_id, qty, price) VALUES ('2015-07-26 08:30:00', (select id from products where product='MB-2'), # product (select id from suppliers where supplier='Cargo Transfer'), # supplier 15, # qty 79); #Вставка поступлений товара actions 41 INSERT INTO actions (action_date, product_id, supplier_id, qty, price) VALUES ('2015-07-26 08:30:00', (select id from products where product='MB-3'), # product (select id from suppliers where supplier='Cargo Transfer'), # supplier 20, # qty 85); #Вставка поступлений товара actions 42 INSERT INTO actions (action_date, product_id, supplier_id, qty, price) VALUES ('2015-07-26 08:30:00', (select id from products where product='MB-4'), # product (select id from suppliers where supplier='Cargo Transfer'), # supplier 23, # qty 88); #Вставка поступлений товара actions 43 INSERT INTO actions (action_date, product_id, supplier_id, qty, price) VALUES ('2015-07-26 08:30:00', (select id from products where product='MB-5'), # product (select id from suppliers where supplier='Cargo Transfer'), # supplier 10, # qty 94); #Вставка поступлений товара actions 44 INSERT INTO actions (action_date, product_id, supplier_id, qty, price) VALUES ('2015-07-28 08:45:00', (select id from products where product='MB-2'), # product (select id from suppliers where supplier='Cargo Transfer'), # supplier 10, # qty 79); #Вставка поступлений товара actions 45 INSERT INTO actions (action_date, product_id, supplier_id, qty, price) VALUES ('2015-07-28 08:45:00', (select id from products where product='MB-4'), # product (select id from suppliers where supplier='Cargo Transfer'), # supplier 7, # qty 89); #Вставка поступлений товара actions 46 INSERT INTO actions (action_date, product_id, supplier_id, qty, price) VALUES ('2015-08-07 08:45:00', (select id from products where product='MB-1'), # product (select id from suppliers where supplier='Cargo Transfer'), # supplier 30, # qty 76); #Вставка поступлений товара actions 47 INSERT INTO actions (action_date, product_id, supplier_id, qty, price) VALUES ('2015-08-07 08:45:00', (select id from products where product='S3 HDD 250Gb, 10000 rpm'), # product (select id from suppliers where supplier='Cargo Transfer'), # supplier 24, # qty 105); #Вставка поступлений товара actions 48 INSERT INTO actions (action_date, product_id, supplier_id, qty, price) VALUES ('2015-08-13 11:12:00', (select id from products where product='MB-1'), # product (select id from suppliers where supplier='Cargo Transfer'), # supplier 10, # qty 75); #Вставка поступлений товара actions 49 INSERT INTO actions (action_date, product_id, supplier_id, qty, price) VALUES ('2015-08-13 11:12:00', (select id from products where product='MB-4'), # product (select id from suppliers where supplier='Cargo Transfer'), # supplier 25, # qty 77); #13.02.2017 #Вставка поступлений товара actions 50 INSERT INTO actions (action_date, product_id, supplier_id, qty, price) VALUES ('2015-11-20 12:30:00', (select id from products where product='MB-7'), # product (select id from suppliers where supplier='Cargo Transfer'), # supplier 17, # qty 181); #Вставка поступлений товара actions 51 INSERT INTO actions (action_date, product_id, supplier_id, qty, price) VALUES ('2015-11-20 12:31:00', (select id from products where product='MB-6'), # product (select id from suppliers where supplier='Cargo Transfer'), # supplier 6, # qty 168); #Вставка поступлений товара actions 52 INSERT INTO actions (action_date, product_id, supplier_id, qty, price) VALUES ('2016-04-03 11:25:00', (select id from products where product='MB-2'), # product (select id from suppliers where supplier='Cargo Transfer'), # supplier 50, # qty 57); #Вставка поступлений товара actions 53 INSERT INTO actions (action_date, product_id, supplier_id, qty, price) VALUES ('2016-04-24 10:35:00', (select id from products where product='MB-3'), # product (select id from suppliers where supplier='Cargo Transfer'), # supplier 60, # qty 63); #Вставка поступлений товара actions 54 INSERT INTO actions (action_date, product_id, supplier_id, qty, price) VALUES ('2016-07-03 10:45:00', (select id from products where product='MB-6'), # product (select id from suppliers where supplier='Cargo Transfer'), # supplier 11, # qty 169); #Вставка поступлений товара actions 55 INSERT INTO actions (action_date, product_id, supplier_id, qty, price) VALUES ('2016-07-07 13:07:00', (select id from products where product='MB-2'), # product (select id from suppliers where supplier='Cargo Transfer'), # supplier 20, # qty 70); #Вставка поступлений товара actions 56 INSERT INTO actions (action_date, product_id, supplier_id, qty, price) VALUES ('2016-07-07 13:08:00', (select id from products where product='MB-5'), # product (select id from suppliers where supplier='Cargo Transfer'), # supplier 25, # qty 144); #Вставка поступлений товара actions 57 INSERT INTO actions (action_date, product_id, supplier_id, qty, price) VALUES ('2016-07-07 13:09:00', (select id from products where product='MB-4'), # product (select id from suppliers where supplier='Cargo Transfer'), # supplier 40, # qty 81); #Вставка поступлений товара actions 58 INSERT INTO actions (action_date, product_id, supplier_id, qty, price) VALUES ('2016-07-16 14:02:00', (select id from products where product='MB-8'), # product (select id from suppliers where supplier='Cargo Transfer'), # supplier 10, # qty 236); #Вставка поступлений товара actions 59 INSERT INTO actions (action_date, product_id, supplier_id, qty, price) VALUES ('2016-08-12 11:37:00', (select id from products where product='MB-7'), # product (select id from suppliers where supplier='Cargo Transfer'), # supplier 12, # qty 180); #Вставка поступлений товара actions 60 INSERT INTO actions (action_date, product_id, supplier_id, qty, price) VALUES ('2016-08-20 10:04:00', (select id from products where product='MB-2'), # product (select id from suppliers where supplier='Cargo Transfer'), # supplier 30, # qty 68); #Вставка поступлений товара actions 61 INSERT INTO actions (action_date, product_id, supplier_id, qty, price) VALUES ('2016-09-11 11:14:00', (select id from products where product='MB-3'), # product (select id from suppliers where supplier='Cargo Transfer'), # supplier 100, # qty 62); #Вставка поступлений товара actions 62 INSERT INTO actions (action_date, product_id, supplier_id, qty, price) VALUES ('2016-10-06 09:57:00', (select id from products where product='S2 HDD 500Gb, 7200 rpm'), # product (select id from suppliers where supplier='Cargo Transfer'), # supplier 10, # qty 74); #Вставка поступлений товара actions 63 INSERT INTO actions (action_date, product_id, supplier_id, qty, price) VALUES ('2016-10-06 09:59:00', (select id from products where product='MB-6'), # product (select id from suppliers where supplier='Cargo Transfer'), # supplier 19, # qty 159); #Вставка поступлений товара actions 64 INSERT INTO actions (action_date, product_id, supplier_id, qty, price) VALUES ('2016-10-7 13:20:00', (select id from products where product='MB-2'), # product (select id from suppliers where supplier='Cargo Transfer'), # supplier 11, # qty 77); #Вставка поступлений товара actions 65 INSERT INTO actions (action_date, product_id, supplier_id, qty, price) VALUES ('2016-10-16 09:48:00', (select id from products where product='MB-4'), # product (select id from suppliers where supplier='Cargo Transfer'), # supplier 3, # qty 91); #Вставка поступлений товара actions 66 INSERT INTO actions (action_date, product_id, supplier_id, qty, price) VALUES ('2016-10-19 10:06:00', (select id from products where product='MB-7'), # product (select id from suppliers where supplier='Cargo Transfer'), # supplier 8, # qty 188); #Вставка поступлений товара actions 67 INSERT INTO actions (action_date, product_id, supplier_id, qty, price) VALUES ('2016-10-27 10:45:00', (select id from products where product='MB-3'), # product (select id from suppliers where supplier='Cargo Transfer'), # supplier 20, # qty 72); #Вставка поступлений товара actions 68 INSERT INTO actions (action_date, product_id, supplier_id, qty, price) VALUES ('2017-02-25 11:12:00', (select id from products where product='MB-1'), # product (select id from suppliers where supplier='Cargo Transfer'), # supplier 25, # qty 63); #Вставка поступлений товара actions 69 INSERT INTO actions (action_date, product_id, supplier_id, qty, price) VALUES ('2017-03-03 14:25:00', (select id from products where product='MB-8'), # product (select id from suppliers where supplier='Cargo Transfer'), # supplier 15, # qty 234); #Вставка поступлений товара actions 70 INSERT INTO actions (action_date, product_id, supplier_id, qty, price) VALUES ('2017-03-06 09:52:00', (select id from products where product='S2 HDD 500Gb, 7200 rpm'), # product (select id from suppliers where supplier='Cargo Transfer'), # supplier 25, # qty 76); #4U #Вставка поступлений товара actions 71 INSERT INTO actions (action_date, product_id, supplier_id, qty, price) VALUES ('2015-07-25 09:05:00', (select id from products where product='S1 HDD 1T, 7200 rpm'), # product (select id from suppliers where supplier='4U'), # supplier 33, # qty 115); #Вставка поступлений товара actions 72 INSERT INTO actions (action_date, product_id, supplier_id, qty, price) VALUES ('2015-07-25 09:05:00', (select id from products where product='Z1 HDD 750Gb, 72000rpm'), # product (select id from suppliers where supplier='4U'), # supplier 40, # qty 90); #Вставка поступлений товара actions 73 INSERT INTO actions (action_date, product_id, supplier_id, qty, price) VALUES ('2015-07-26 16:45:00', (select id from products where product='UN1 HDD 750Gb, 72000rpm'), # product (select id from suppliers where supplier='4U'), # supplier 100, # qty 94); #Вставка поступлений товара actions 74 INSERT INTO actions (action_date, product_id, supplier_id, qty, price) VALUES ('2015-07-28 09:10:00', (select id from products where product='S5 HDD 500Gb, 7200rpm'), # product (select id from suppliers where supplier='4U'), # supplier 80, # qty 86); #Вставка поступлений товара actions 75 INSERT INTO actions (action_date, product_id, supplier_id, qty, price) VALUES ('2015-08-03 14:15:00', (select id from products where product='DDR3 SST 4Gb'), # product (select id from suppliers where supplier='4U'), # supplier 100, # qty 34); #Вставка поступлений товара actions 76 INSERT INTO actions (action_date, product_id, supplier_id, qty, price) VALUES ('2015-08-03 14:15:00', (select id from products where product='Monitor DD27'), # product (select id from suppliers where supplier='4U'), # supplier 10, # qty 345); #Вставка поступлений товара actions 77 INSERT INTO actions (action_date, product_id, supplier_id, qty, price) VALUES ('2015-08-13 10:00:00', (select id from products where product='Monitor DD27'), # product (select id from suppliers where supplier='4U'), # supplier 5, # qty 345); #Вставка поступлений товара actions 78 INSERT INTO actions (action_date, product_id, supplier_id, qty, price) VALUES ('2015-08-13 10:00:00', (select id from products where product='MB-8'), # product (select id from suppliers where supplier='4U'), # supplier 30, # qty 235); #Вставка поступлений товара actions 79 INSERT INTO actions (action_date, product_id, supplier_id, qty, price) VALUES ('2015-08-15 17:15:00', (select id from products where product='DDR3 BTT 4Gb'), # product (select id from suppliers where supplier='4U'), # supplier 100, # qty 39); #Вставка поступлений товара actions 80 INSERT INTO actions (action_date, product_id, supplier_id, qty, price) VALUES ('2015-08-16 09:45:00', (select id from products where product='MB-7'), # product (select id from suppliers where supplier='4U'), # supplier 50, # qty 180); #Вставка поступлений товара actions 81 INSERT INTO actions (action_date, product_id, supplier_id, qty, price) VALUES ('2015-08-16 09:45:00', (select id from products where product='Monitor DD27'), # product (select id from suppliers where supplier='4U'), # supplier 12, # qty 350); #13.02.2017 #Вставка поступлений товара actions 82 INSERT INTO actions (action_date, product_id, supplier_id, qty, price) VALUES ('2015-12-19 09:23:00', (select id from products where product='Z1 HDD 750Gb, 72000rpm'), # product (select id from suppliers where supplier='4U'), # supplier 50, # qty 79); #Вставка поступлений товара actions 83 INSERT INTO actions (action_date, product_id, supplier_id, qty, price) VALUES ('2016-01-07 10:10:00', (select id from products where product='Z2 HDD 750Gb, 72000rpm'), # product (select id from suppliers where supplier='4U'), # supplier 30, # qty 94); #Вставка поступлений товара actions 84 INSERT INTO actions (action_date, product_id, supplier_id, qty, price) VALUES ('2016-01-09 10:23:00', (select id from products where product='DDR3 UNK 2Gb'), # product (select id from suppliers where supplier='4U'), # supplier 25, # qty 18); #Вставка поступлений товара actions 85 INSERT INTO actions (action_date, product_id, supplier_id, qty, price) VALUES ('2016-01-23 15:45:00', (select id from products where product='DDR3 BTT 4Gb'), # product (select id from suppliers where supplier='4U'), # supplier 60, # qty 39); #Вставка поступлений товара actions 86 INSERT INTO actions (action_date, product_id, supplier_id, qty, price) VALUES ('2016-01-25 13:17:00', (select id from products where product='Z1 HDD 750Gb, 72000rpm'), # product (select id from suppliers where supplier='4U'), # supplier 5, # qty 101); #Вставка поступлений товара actions 87 INSERT INTO actions (action_date, product_id, supplier_id, qty, price) VALUES ('2016-02-01 09:45:00', (select id from products where product='Monitor DD27'), # product (select id from suppliers where supplier='4U'), # supplier 5, # qty 351); #Вставка поступлений товара actions 88 INSERT INTO actions (action_date, product_id, supplier_id, qty, price) VALUES ('2016-02-25 09:15:00', (select id from products where product='MB-8'), # product (select id from suppliers where supplier='4U'), # supplier 20, # qty 225); #Вставка поступлений товара actions 89 INSERT INTO actions (action_date, product_id, supplier_id, qty, price) VALUES ('2016-02-25 10:03:00', (select id from products where product='UN1 HDD 750Gb, 72000rpm'), # product (select id from suppliers where supplier='4U'), # supplier 16, # qty 93); #Вставка поступлений товара actions 90 INSERT INTO actions (action_date, product_id, supplier_id, qty, price) VALUES ('2016-03-09 17:43:00', (select id from products where product='DDR3 BTT 8Gb'), # product (select id from suppliers where supplier='4U'), # supplier 24, # qty 75); #Вставка поступлений товара actions 91 INSERT INTO actions (action_date, product_id, supplier_id, qty, price) VALUES ('2016-03-18 13:06:00', (select id from products where product='MB-7'), # product (select id from suppliers where supplier='4U'), # supplier 10, # qty 183); #Вставка поступлений товара actions 92 INSERT INTO actions (action_date, product_id, supplier_id, qty, price) VALUES ('2016-03-24 11:18:00', (select id from products where product='Z1 HDD 750Gb, 72000rpm'), # product (select id from suppliers where supplier='4U'), # supplier 40, # qty 92); #Вставка поступлений товара actions 93 INSERT INTO actions (action_date, product_id, supplier_id, qty, price) VALUES ('2016-03-24 11:19:00', (select id from products where product='Z2 HDD 750Gb, 72000rpm'), # product (select id from suppliers where supplier='4U'), # supplier 35, # qty 99); #Вставка поступлений товара actions 94 INSERT INTO actions (action_date, product_id, supplier_id, qty, price) VALUES ('2016-03-24 11:20:00', (select id from products where product='DDR3 ZPP 4Gb'), # product (select id from suppliers where supplier='4U'), # supplier 20, # qty 37); #Вставка поступлений товара actions 95 INSERT INTO actions (action_date, product_id, supplier_id, qty, price) VALUES ('2016-04-12 15:55:00', (select id from products where product='UN1 HDD 750Gb, 72000rpm'), # product (select id from suppliers where supplier='4U'), # supplier 50, # qty 95); #Вставка поступлений товара actions 96 INSERT INTO actions (action_date, product_id, supplier_id, qty, price) VALUES ('2016-05-18 13:15:00', (select id from products where product='MB-8'), # product (select id from suppliers where supplier='4U'), # supplier 1, # qty 255); #Вставка поступлений товара actions 97 INSERT INTO actions (action_date, product_id, supplier_id, qty, price) VALUES ('2016-05-18 13:15:00', (select id from products where product='MB-7'), # product (select id from suppliers where supplier='4U'), # supplier 3, # qty 196); #Вставка поступлений товара actions 98 INSERT INTO actions (action_date, product_id, supplier_id, qty, price) VALUES ('2016-06-01 10:05:00', (select id from products where product='DDR3 ZPP 4Gb'), # product (select id from suppliers where supplier='4U'), # supplier 60, # qty 34); #Вставка поступлений товара actions 99 INSERT INTO actions (action_date, product_id, supplier_id, qty, price) VALUES ('2016-07-01 12:21:00', (select id from products where product='Monitor DD27'), # product (select id from suppliers where supplier='4U'), # supplier 7, # qty 348); #Вставка поступлений товара actions 100 INSERT INTO actions (action_date, product_id, supplier_id, qty, price) VALUES ('2016-12-13 09:52:00', (select id from products where product='DDR3 ZPP 4Gb'), # product (select id from suppliers where supplier='4U'), # supplier 10, # qty 42); #Вставка поступлений товара actions 101 INSERT INTO actions (action_date, product_id, supplier_id, qty, price) VALUES ('2017-01-20 15:35:00', (select id from products where product='S1 HDD 1T, 7200 rpm'), # product (select id from suppliers where supplier='4U'), # supplier 20, # qty 115); #Вставка поступлений товара actions 102 INSERT INTO actions (action_date, product_id, supplier_id, qty, price) VALUES ('2017-02-25 16:05:00', (select id from products where product='DDR3 SST 4Gb'), # product (select id from suppliers where supplier='4U'), # supplier 80, # qty 36); #Вставка поступлений товара actions 103 INSERT INTO actions (action_date, product_id, supplier_id, qty, price) VALUES ('2017-03-12 12:45:00', (select id from products where product='DDR3 BTT 4Gb'), # product (select id from suppliers where supplier='4U'), # supplier 50, # qty 39); #IDT #Вставка поступлений товара actions 104 INSERT INTO actions (action_date, product_id, supplier_id, qty, price) VALUES ('2015-07-29 13:00:00', (select id from products where product='S5 HDD 500Gb, 7200rpm'), # product (select id from suppliers where supplier='IDT'), # supplier 120, # qty 78); #Вставка поступлений товара actions 105 INSERT INTO actions (action_date, product_id, supplier_id, qty, price) VALUES ('2015-07-29 13:00:00', (select id from products where product='S3 HDD 250Gb, 10000 rpm'), # product (select id from suppliers where supplier='IDT'), # supplier 80, # qty 130); #Вставка поступлений товара actions 106 INSERT INTO actions (action_date, product_id, supplier_id, qty, price) VALUES ('2015-08-10 09:50:00', (select id from products where product='S5 HDD 500Gb, 7200rpm'), # product (select id from suppliers where supplier='IDT'), # supplier 60, # qty 78); #Вставка поступлений товара actions 107 INSERT INTO actions (action_date, product_id, supplier_id, qty, price) VALUES ('2015-08-12 10:10:00', (select id from products where product='S3 HDD 250Gb, 10000 rpm'), # product (select id from suppliers where supplier='IDT'), # supplier 85, # qty 129); #13.02.2017 #Вставка поступлений товара actions 108 INSERT INTO actions (action_date, product_id, supplier_id, qty, price) VALUES ('2016-02-12 09:15:00', (select id from products where product='S3 HDD 250Gb, 10000 rpm'), # product (select id from suppliers where supplier='IDT'), # supplier 100, # qty 127); #Вставка поступлений товара actions 109 INSERT INTO actions (action_date, product_id, supplier_id, qty, price) VALUES ('2016-02-25 17:02:00', (select id from products where product='S2 HDD 500Gb, 7200 rpm'), # product (select id from suppliers where supplier='IDT'), # supplier 50, # qty 73); #Вставка поступлений товара actions 110 INSERT INTO actions (action_date, product_id, supplier_id, qty, price) VALUES ('2016-02-25 17:03:00', (select id from products where product='S1 HDD 1T, 7200 rpm'), # product (select id from suppliers where supplier='IDT'), # supplier 63, # qty 99); #Вставка поступлений товара actions 111 INSERT INTO actions (action_date, product_id, supplier_id, qty, price) VALUES ('2016-02-25 17:03:00', (select id from products where product='S5 HDD 500Gb, 7200rpm'), # product (select id from suppliers where supplier='IDT'), # supplier 20, # qty 82); #Вставка поступлений товара actions 112 INSERT INTO actions (action_date, product_id, supplier_id, qty, price) VALUES ('2016-06-14 16:03:00', (select id from products where product='S3 HDD 250Gb, 10000 rpm'), # product (select id from suppliers where supplier='IDT'), # supplier 25, # qty 127); #Вставка поступлений товара actions 113 INSERT INTO actions (action_date, product_id, supplier_id, qty, price) VALUES ('2016-07-19 10:25:00', (select id from products where product='S3 HDD 250Gb, 10000 rpm'), # product (select id from suppliers where supplier='IDT'), # supplier 20, # qty 127); #Вставка поступлений товара actions 114 INSERT INTO actions (action_date, product_id, supplier_id, qty, price) VALUES ('2016-09-01 09:25:00', (select id from products where product='S1 HDD 1T, 7200 rpm'), # product (select id from suppliers where supplier='IDT'), # supplier 30, # qty 116); #Вставка поступлений товара actions 115 INSERT INTO actions (action_date, product_id, supplier_id, qty, price) VALUES ('2016-11-01 10:10:00', (select id from products where product='S2 HDD 500Gb, 7200 rpm'), # product (select id from suppliers where supplier='IDT'), # supplier 30, # qty 73); #Вставка поступлений товара actions 116 INSERT INTO actions (action_date, product_id, supplier_id, qty, price) VALUES ('2016-12-25 13:09:00', (select id from products where product='S5 HDD 500Gb, 7200rpm'), # product (select id from suppliers where supplier='IDT'), # supplier 20, # qty 83); #Вставка поступлений товара actions 117 INSERT INTO actions (action_date, product_id, supplier_id, qty, price) VALUES ('2017-01-11 09:15:00', (select id from products where product='S4 HDD 1T, 7200rpm'), # product (select id from suppliers where supplier='IDT'), # supplier 15, # qty 120); #Вставка поступлений товара actions 118 INSERT INTO actions (action_date, product_id, supplier_id, qty, price) VALUES ('2017-01-14 10:22:00', (select id from products where product='S3 HDD 250Gb, 10000 rpm'), # product (select id from suppliers where supplier='IDT'), # supplier 90, # qty 127); #Вставка поступлений товара actions 119 INSERT INTO actions (action_date, product_id, supplier_id, qty, price) VALUES ('2017-01-29 10:30:00', (select id from products where product='S2 HDD 500Gb, 7200 rpm'), # product (select id from suppliers where supplier='IDT'), # supplier 40, # qty 77); #Вставка поступлений товара actions 120 INSERT INTO actions (action_date, product_id, supplier_id, qty, price) VALUES ('2017-02-10 15:56:00', (select id from products where product='S4 HDD 1T, 7200rpm'), # product (select id from suppliers where supplier='IDT'), # supplier 20, # qty 118); #Вставка поступлений товара actions 121 INSERT INTO actions (action_date, product_id, supplier_id, qty, price) VALUES ('2017-02-10 15:57:00', (select id from products where product='S1 HDD 1T, 7200 rpm'), # product (select id from suppliers where supplier='IDT'), # supplier 25, # qty 116); #Вставка поступлений товара actions 122 INSERT INTO actions (action_date, product_id, supplier_id, qty, price) VALUES ('2017-02-22 11:37:00', (select id from products where product='S5 HDD 500Gb, 7200rpm'), # product (select id from suppliers where supplier='IDT'), # supplier 65, # qty 80); #Вставка поступлений товара actions 123 INSERT INTO actions (action_date, product_id, supplier_id, qty, price) VALUES ('2017-02-28 08:47:00', (select id from products where product='S3 HDD 250Gb, 10000 rpm'), # product (select id from suppliers where supplier='IDT'), # supplier 10, # qty 145); #Вставка поступлений товара actions 124 INSERT INTO actions (action_date, product_id, supplier_id, qty, price) VALUES ('2017-03-05 10:45:00', (select id from products where product='S4 HDD 1T, 7200rpm'), # product (select id from suppliers where supplier='IDT'), # supplier 100, # qty 109); #Вставка поступлений товара actions 125 INSERT INTO actions (action_date, product_id, supplier_id, qty, price) VALUES ('2017-03-10 13:23:00', (select id from products where product='S5 HDD 500Gb, 7200rpm'), # product (select id from suppliers where supplier='IDT'), # supplier 45, # qty 84); Задание 1 Написать SQL запрос, в результате которого выводятся данные о суммах поставок, сгруппированные по брендам. Товары без бренда рассматривать как отдельную группу. В результате запроса выводить названия брендов и суммы поставок по брендам. Задание 2 Написать SQL запрос, в результате которого выводятся данные об итоговых суммах поставок для каждого поставщика и категории товара за 2016 год. Задание 3 Написать SQL запрос, в результате которого выводятся среднегодовые цены поставки для каждой категории товара, а также максимальная и минимальная цена за год. Также в запрос нужно вывести название категории товаров, год. Цены должны быть рассчитаны по каждому году, за который есть данные в базе. Данные должны быть отсортированы по категории и году. Алгоритм расчета средней цены поставки за какой-либо период: например, было две поставки по категории товара: 50 единиц по 10 долларов за единицу, 20 единиц по 15 долларов за единицу. Расчет средней цены с учетом количества: общая сумма поставок делится на общее количество: (50 ед. *10 долл. + 20 ед. *15 долл.)/(50 ед.+20 ед.) = 11,42857 ... |
| 28.01.2022, 07:37:15 |
Вам сюда: https://www.sql.ru/forum/job ... |
| 28.01.2022, 08:34:55 |
| 28.01.2022, 08:38:02 |
start [/forum/topic.php?fid=47&gotonew=1&tid=1827802]: |
480ms |
33ms |
| others: | 224ms |
| total: | 776ms |
