Client SP3
Нужно ли ставить SP3 на клиента SQL ??? ... |
| 28.12.2000, 18:28 |
Client SP3
Судите сами http://www.microsoft.com/sql/downloads/sp3.htm : SP3 updates for the database components of SQL Server 7.0 and MSDE 1.0 include ... Database client connectivity components, such as the OLE DB Provider for SQL Server, the SQL Server Open Database Connectivity (ODBC) driver, and the client Net-Libraries Ответ - да. ... |
| 08.01.2001, 15:11 |
start [/forum/topic.php?fid=46&gotonew=1&tid=1827499]: |
183ms |
48ms |
| others: | 210ms |
| total: | 491ms |
