Опитимизация работы sp_
Друзья! помогите ускорить работу процедуры если это возможно. Если нет сообщите. В Transact-SQL пока не силен, а работу требуют! CREATE PROCEDURE zsp_TEST AS insert into ZTest select a.id,a.name,a.crdate,b.name,c.name,b.length,b.xprec,b.xscale,b.typestat, b.isnullable,b.cdefault,b.status,'новая таблица' from sysobjects a, syscolumns b, systypes c where a.id=b.id and b.xtype=c.xtype and a.name not in(select name from ZTest)and a.type='U' and a.name <> 'dtproperties' and a.name<>'ZTest' insert into ZTest select a.id,a.name,a.crdate,b.name,c.name,b.length,b.xprec,b.xscale,b.typestat, b.isnullable,b.cdefault,b.status,'данные изменены' from sysobjects a, syscolumns b, systypes c, ZTest d where a.id=b.id and b.xtype=c.xtype and a.name=d.name and b.name=d.column_name and a.type='U' and a.name <> 'dtproperties' and a.name<> 'ZTest' and (c.name<>d.type_dan or b.length<>d.length or b.xprec<>d.prec or b.xscale<>d.scale or b.typestat<>d.typestat or b.isnullable<>d.nullable or b.cdefault<>d.default_value or b.status<>d.status) order by d.name insert into ZTest select distinct a.id,a.name,a.crdate,b.name,c.name,b.length,b.xprec,b.xscale,b.typestat,b.isnullable, b.cdefault,b.status,'новый столбец' from sysobjects a, syscolumns b, systypes c, ZTest d where a.id=b.id and b.xtype=c.xtype and RTRIM(a.name)+RTRIM(b.name) not in (select RTRIM(name)+RTRIM(column_name) from ZTest) and a.type='U' and a.name <> 'dtproperties' and a.name<>'ZTest' update ZTest set change='столбец удален' where RTRIM(ZTest.name)+RTRIM(ZTest.column_name) not in (select RTRIM(sysobjects.name)+RTRIM(syscolumns.name) from sysobjects,syscolumns) and (ZTest.change='новая таблица'or ZTest.change='данные изменены' or ZTest.change='новый столбец') ... |
| 09.04.2001, 15:55:26 |
start [/forum/topic.php?fid=46&gotonew=1&tid=1827037]: |
186ms |
40ms |
| others: | 188ms |
| total: | 464ms |
