что не так?
Из QA пытаюсь выполнить следующее: USE db_users IF EXISTS (SELECT * FROM sysobjects WHERE name='spStartSessionChecking' AND type='P') DROP PROCEDURE spStartSessionChecking GO CREATE PROCEDURE spStartSessionChecking AS EXEC sp_add_job @job_name='jbSessionChecking' EXEC sp_add_jobstep @job_name='jbSessionChecking', @subsystem = 'TSQL', @command = 'exec spCheckUsersSessions' EXEC sp_add_jobschedule @job_name='jbSessionChecking', @freq_type = 4, @freq_interval = 1, @freq_subday_type = 0x4, @freq_subday_interval = 10 GO IF EXISTS (SELECT * FROM sysobjects WHERE name='spEndSessionChecking' AND type='P') DROP PROCEDURE spEndSessionChecking GO CREATE PROCEDURE spEndSessionChecking AS EXEC sp_delete_job @job_name='jbSessionChecking' GO ---------------------- Получаю: Cannot add rows to sysdepends for the current stored procedure because it depends on the missing object 'sp_add_job'. The stored procedure will still be created. Cannot add rows to sysdepends for the current stored procedure because it depends on the missing object 'sp_add_jobstep'. The stored procedure will still be created. Cannot add rows to sysdepends for the current stored procedure because it depends on the missing object 'sp_add_jobschedule'. The stored procedure will still be created. Cannot add rows to sysdepends for the current stored procedure because it depends on the missing object 'sp_delete_job'. The stored procedure will still be created. ----------- why and how? great thanks for every comment ... |
| 03.06.2001, 12:30:59 |
что не так?
В db_users нет этих процедур. Используйте "exec master..sp_addJob" И т.д. ... |
| 04.06.2001, 01:45:26 |
что не так?
Не. Надо писать msdb..sp_addjob ... |
| 04.06.2001, 13:20:14 |
start [/forum/topic.php?fid=46&gotonew=1&tid=1826591]: |
189ms |
50ms |
| others: | 200ms |
| total: | 490ms |
