HELP PLEASE !!! SOS !!! SELECT !
HELP PLEASE !!! =============== Есть выборка: use hotel select guest.status, z_rooms.roomtype, guest.room, datediff(dd,guest.arrival,guest.departure)'Days' from guest, z_rooms where guest.status='O' and (guest.arrival >= '2001-01-01' and guest.departure <= '2001-05-31') and (guest.room=z_rooms.code) Запрос возвращает: status roomtype room Days ------ ------------ ------ ----------- O STtb 1001 3 O STtb 1001 2 O STtb 1001 1 O STtb 1001 1 O STtb 1001 2 O STtb 1001 3 O STtb 1001 4 O STtb 1001 1 O STtb 1002 3 O STtb 1002 3 Как мне отобразить значения "ROOM" без повторений, подсчитать повторения каждого "ROOM" и вывести в отдельный столбец (например 1001 повторялся 8 раз и т.д.) ... |
| 15.06.2001, 06:51:25 |
use hotel select guest.status, z_rooms.roomtype, guest.room, count(*) as cnt, sum( datediff(dd,guest.arrival,guest.departure) ) 'Days' from guest, z_rooms where guest.status='O' and (guest.arrival >= '2001-01-01' and guest.departure <= '2001-05-31') and (guest.room=z_rooms.code) group by guest.status,z_rooms.roomtype, guest.room order by by guest.status,z_rooms.roomtype, guest.room ... |
| 15.06.2001, 06:59:47 |
start [/forum/topic.php?fid=46&gotonew=1&tid=1826488]: |
175ms |
36ms |
| others: | 190ms |
| total: | 446ms |
