EXCEPTION_FLT_OVERFLOW на SQL 7.0
Запускаю такой запрос из QA: select SC351.SP1628, SC351.PARENTID, SC391.PARENTEXT, convert(numeric(10, 2), _1SCONST.VALUE) , convert(numeric(10, 2), _1SCONST1.VALUE) * SC391.SP1659 , convert(numeric(10, 2), _1SCONST2.VALUE) * SC391.SP379 , convert(numeric(10, 2), _1SCONST3.VALUE) * 0, convert(numeric(10, 2), _1SCONST4.VALUE) * SC391.SP8184 , _1SCONST5.VALUE, SC391.SP1666, SC391.ID, SC391.SP8187, SC391.SP8184, convert(numeric(10, 2), _1SCONST6.VALUE), SC391.SP1659, SC391.SP379, SC391.SP1658 from SC391(NOLOCK) left outer join SC351(NOLOCK) on SC391.PARENTEXT=SC351.ID left outer join _1SCONST(NOLOCK) on (_1SCONST.ID = 1653 and _1SCONST.OBJID = SC391.ID and convert(CHAR(, _1SCONST.DATE, 112) + convert(CHAR(10), _1SCONST.TIME) = (select max(convert(CHAR(, DATE, 112) + convert(CHAR(10), TIME)) from _1SCONST where ID = 1653 and OBJID = SC391.ID and (DATE < '20010601' or DATE = '20010601' and TIME <= 936600000)) and _1SCONST.DOCID = (select max(DOCID) from _1SCONST _1SCONST_OTHER1 where ID = 1653 and OBJID = SC391.ID and _1SCONST.DATE = DATE and _1SCONST.TIME = TIME)) left outer join _1SCONST _1SCONST1(NOLOCK) on (_1SCONST1.ID = 1653 and _1SCONST1.OBJID = SC391.ID and convert(CHAR(, _1SCONST1.DATE, 112) + convert(CHAR(10), _1SCONST1.TIME) = (select max(convert(CHAR(, DATE, 112) + convert(CHAR(10), TIME)) from _1SCONST where ID = 1653 and OBJID = SC391.ID and (DATE < '20010601' or DATE = '20010601' and TIME <= 936600000)) and _1SCONST1.DOCID = (select max(DOCID) from _1SCONST _1SCONST1_OTHER1 where ID = 1653 and OBJID = SC391.ID and _1SCONST1.DATE = DATE and _1SCONST1.TIME = TIME)) left outer join _1SCONST _1SCONST2(NOLOCK) on (_1SCONST2.ID = 1653 and _1SCONST2.OBJID = SC391.ID and convert(CHAR(, _1SCONST2.DATE, 112) + convert(CHAR(10), _1SCONST2.TIME) = (select max(convert(CHAR(, DATE, 112) + convert(CHAR(10), TIME)) from _1SCONST where ID = 1653 and OBJID = SC391.ID and (DATE < '20010601' or DATE = '20010601' and TIME <= 936600000)) and _1SCONST2.DOCID = (select max(DOCID) from _1SCONST _1SCONST2_OTHER1 where ID = 1653 and OBJID = SC391.ID and _1SCONST2.DATE = DATE and _1SCONST2.TIME = TIME)) left outer join _1SCONST _1SCONST3(NOLOCK) on (_1SCONST3.ID = 1653 and _1SCONST3.OBJID = SC391.ID and convert(CHAR(, _1SCONST3.DATE, 112) + convert(CHAR(10), _1SCONST3.TIME) = (select max(convert(CHAR(, DATE, 112) + convert(CHAR(10), TIME)) from _1SCONST where ID = 1653 and OBJID = SC391.ID and (DATE < '20010601' or DATE = '20010601' and TIME <= 936600000)) and _1SCONST3.DOCID = (select max(DOCID) from _1SCONST _1SCONST3_OTHER1 where ID = 1653 and OBJID = SC391.ID and _1SCONST3.DATE = DATE and _1SCONST3.TIME = TIME)) left outer join _1SCONST _1SCONST4(NOLOCK) on (_1SCONST4.ID = 1653 and _1SCONST4.OBJID = SC391.ID and convert(CHAR(, _1SCONST4.DATE, 112) + convert(CHAR(10), _1SCONST4.TIME) = (select max(convert(CHAR(, DATE, 112) + convert(CHAR(10), TIME)) from _1SCONST where ID = 1653 and OBJID = SC391.ID and (DATE < '20010601' or DATE = '20010601' and TIME <= 936600000)) and _1SCONST4.DOCID = (select max(DOCID) from _1SCONST _1SCONST4_OTHER1 where ID = 1653 and OBJID = SC391.ID and _1SCONST4.DATE = DATE and _1SCONST4.TIME = TIME)) left outer join _1SCONST _1SCONST5(NOLOCK) on (_1SCONST5.ID = 8154 and _1SCONST5.OBJID = SC391.PARENTEXT and convert(CHAR(, _1SCONST5.DATE, 112) + convert(CHAR(10), _1SCONST5.TIME) = (select max(convert(CHAR(, DATE, 112) + convert(CHAR(10), TIME)) from _1SCONST where ID = 8154 and OBJID = SC391.PARENTEXT and (DATE < '20010601' or DATE = '20010601' and TIME <= 936600000)) and _1SCONST5.DOCID = (select max(DOCID) from _1SCONST _1SCONST5_OTHER1 where ID = 8154 and OBJID = SC391.PARENTEXT and _1SCONST5.DATE = DATE and _1SCONST5.TIME = TIME)) left outer join _1SCONST _1SCONST6(NOLOCK) on (_1SCONST6.ID = 1653 and _1SCONST6.OBJID = SC391.ID and convert(CHAR(, _1SCONST6.DATE, 112) + convert(CHAR(10), _1SCONST6.TIME) = (select max(convert(CHAR(, DATE, 112) + convert(CHAR(10), TIME)) from _1SCONST where ID = 1653 and OBJID = SC391.ID and (DATE < '20010601' or DATE = '20010601' and TIME <= 936600000)) and _1SCONST6.DOCID = (select max(DOCID) from _1SCONST _1SCONST6_OTHER1 where ID = 1653 and OBJID = SC391.ID and _1SCONST6.DATE = DATE and _1SCONST6.TIME = TIME)) Получаю такой ответ: ODBC: Msg 0, Level 19, State 1 SqlDumpExceptionHandler: Process хх generated fatal exception c0000091 EXCEPTION_FLT_OVERFLOW. SQL Server is terminating this process. [Microsoft][ODBC SQL Server Driver][Named Pipes]ConnectionWrite (WriteFile()). [Microsoft][ODBC SQL Server Driver]Communication link failure Connection Broken Если сразу же ещё раз запускаю, то Changed language setting to us_english. Changed language setting to us_english. ODBC: Msg 0, Level 19, State 1 SqlDumpExceptionHandler: Process хх generated fatal exception c0000091 EXCEPTION_FLT_OVERFLOW. SQL Server is terminating this process. [Microsoft][ODBC SQL Server Driver][Named Pipes]ConnectionCheckForData (PeekNamedPipe()). [Microsoft][ODBC SQL Server Driver][Named Pipes]Connection broken. Connection Broken В случае сетевой библиотеки TCP/IP : [Microsoft][ODBC SQL Server Driver][TCP/IP Sockets]ConnectionCheckForData ((null)()). [Microsoft][ODBC SQL Server Driver][TCP/IP Sockets]General network error. Check your network documentation. Connection Broken Пробовал на разном железе - одно и тоже. Раньше не пробовал. Этот запрос генерирует 1С:Предприятие. Использую SQL 7.0 SP1 на NT Server 4.0. База 460 Мб. Таблица _1SCONST -233000 записей. ODBC из MDAC 2.5. Если убрать один join - всё работает. План запроса не создаётся. Чё делать -то, кто скажет. С чем енто кушать? Поможитя - 1с не работает. ... |
| 04.07.2001, 14:11 |
start [/forum/topic.php?fid=46&gotonew=1&tid=1826285]: |
210ms |
44ms |
| others: | 243ms |
| total: | 561ms |
