INSERT row in table with single IDENTITY field
I have table with one Identity field : CREATE TABLE [dbo].[Table1] ( [id] [int] IDENTITY (1, 1) NOT NULL ) ON [PRIMARY] I can't INSERT new row. INSERT with OPTION IDENTITY_INSERT OFF not worked. The trouble happen because is only one field in the table Please help me! Sorry i speak russian but not have russian keyboard. Thanks ... |
| 07.08.2001, 08:03 |
У меня работает нормально так: \nset identity_insert table1 on insert table1 (id) values (1) set identity_insert table1 off И так: \ninsert table1 default values ... |
| 07.08.2001, 08:23 |
Thanks The second solution was excellent !!! (insert table1 default values) ... |
| 07.08.2001, 09:19 |
start [/forum/topic.php?fid=46&gotonew=1&tid=1825956]: |
142ms |
27ms |
| others: | 241ms |
| total: | 450ms |
