AutostartServer & Win98
Привет! Для того, чтобы SQL Server запускался сразу после загрузки Windows из своего приложения на VB я выполняю SQLSrv.Registry.AutostartServer = True Это не работает под Win98. Почему? Как из приложения устанавливать этот параметр? Спасибо ... |
| 20.10.2001, 11:15 |
BOL "Starting SQL Server Automatically During installation, you can configure Microsoft® SQL Server™ to start automatically in the following ways: You can configure an instance of SQL Server to start automatically each time you start the Microsoft Windows NT® 4.0 or Windows® 2000 operating system. You can configure a server running Microsoft Windows 98 to start automatically. Select the Auto-start service when OS starts check box in SQL Server Service Manager. Windows 98 does not have a component that corresponds to Window NT 4.0 and Windows 2000 services. The SQL Server database engine and SQL Server Agent run as executable programs on Windows 98. These SQL Server components cannot be started as services automatically. Note The SQL-DMO AutoStartServer property does not work with Windows 98 . You can also use the Services application in Control Panel. After SQL Server is installed, you can enable or disable the server configuration using SQL Server Enterprise Manager. For more information, see the Windows NT 4.0 and Windows 2000 documentation " Или можно стартовать сервер используя команду "sqlservr Application The sqlservr application starts, stops, pauses, and continues an instance of Microsoft® SQL Server™ 2000 from a command prompt. Syntax sqlservr [-sinstance_name] [-c] [-dmaster_path] [-f] [-eerror_log_path] [-lmaster_log_path] [-m] [-n] [-Ttrace#] [-v] [-x] [-g number] [-O] [-y number] Arguments-sinstance_name Specifies the instance of SQL Server to connect to. If no named instance is specified, sqlservr starts the default instance of SQL Server. Important When starting an instance of SQL Server, you must use the sqlservr application in the appropriate directory for that instance. For the default instance, run sqlservr from the \MSSQL\Binn directory. For a named instance, run sqlservr from the \MSSQL$instance_name\Binn directory. -c Indicates that an instance of SQL Server is started independently of the Windows NT Service Control Manager. This option is used when starting SQL Server from a command prompt, to shorten the amount of time it takes for SQL Server to start. (Note that when you use this option, you cannot stop SQL Server by using SQL Server Service Manager or the net stop command, and if you log off the Microsoft Windows NT® system, SQL Server will be stopped.) -dmaster_path Indicates the fully qualified path for the master database file. There are no spaces between -d and master_path. -f Starts the server in minimally configured mode. The system administrator can then reconfigure configuration options (with the sp_configure system stored procedure). -eerror_log_path Indicates the fully qualified path for the error log file. If not specified, the default location is x:\Program Files\Microsoft SQL Server\MSSQL\Log\Errorlog for the default instance and x:\Program Files\Microsoft SQL Server\MSSQL$instance_name\Log\Errorlog for a named instance. There are no spaces between -e and error_log_path. -lmaster_log_path Indicates the fully qualified path for the master database transaction log file. There are no spaces between -l and master_log_path. -m Indicates to start an instance of SQL Server in single-user mode. Only a single user can connect when SQL Server is started in single-user mode. The CHECKPOINT mechanism, which guarantees that completed transactions are regularly written from the disk cache to the database device, is not started. (Typically, this option is used if you experience problems with system databases that require repair.) -n Indicates that you do not want to use the Windows NT application log to log SQL Server events. If you start an instance of SQL Server with the -n option, it is advisable to use the -e option too, or SQL Server events are not logged. -Ttrace# Indicates that an instance of SQL Server should be started with a specified trace flag (trace#) in effect. Trace flags are used to start servers with nonstandard behavior. For more information about available trace flags (trace#), see Trace Flags. Important When specifying a trace flag, use -T to pass the trace flag number. A lowercase t (-t) is accepted by SQL Server; however, -t sets other internal trace flags required by SQL Server support engineers. -v Displays the server version number. -x Disables maintaining CPU statistics. -g memory_to_reserve Specifies an integer number of megabytes of memory to reserve for other applications running within (in-process) SQL Server 2000. -O Specifies that Distributed COM (DCOM) is not required, thereby disabling heterogeneous queries. -y error_number If SQL Server 2000 encounters an error message specified in this option, it writes the symptom stack trace to the error log. You can specify multiple errors by using multiple –y arguments. " ... |
| 20.10.2001, 12:45 |
start [/forum/topic.php?fid=46&gotonew=1&tid=1825258]: |
46ms |
| others: | 195ms |
| total: | 297ms |
