3 fields into 1
Kak napisal sql zapros, chtoby znachenija iz trioh polej skopirovat v odno, polia texstovye, tablica odna i taze. ... |
| 08.11.2001, 20:08 |
3 fields into 1
dannyj VB kod eto delaet, a kak v SQL server cherez sql-language eto selat? Option Explicit Dim cn1 As ADODB.Connection Dim rs1 As ADODB.Recordset Dim str, str2, f Private Sub Command1_Click() rs1.CursorLocation = adUseClient rs1.Open "select id,Exp_Adopt_Parents,Exp_CHDWEL,[Exp_ Father],Exp_Foster,Exp_Gay,Exp_Grandpar,Exp_Homeless,Exp_Immig,Exp_Jail,Exp_Military,Exp_Single,Exp_Teenpar,Exp_Youth,Exp_Other from programs", cn1 Do While Not rs1.EOF For Each f In rs1.Fields Debug.Print str If f <> "N/A" Then If f.Name <> "id" Then str = str & "," & rs1(f.Name) End If End If Next str = Mid(str, 2) If Len(str) < 3 Then str = "N/A" str2 = "update programs set expert='" & str & "' where id=" & rs1("id") cn1.Execute (str2) DoEvents Text1.Text = rs1("id") str = "" rs1.MoveNext Loop Text1.Text = "End" End Sub Private Sub Form_Load() Set cn1 = New ADODB.Connection Set rs1 = New ADODB.Recordset cn1.Provider = "sqloledb.1" cn1.ConnectionString = "server=iosif;database=mapping;uid=iosif;pwd=guk;" cn1.ConnectionTimeout = 3600 cn1.Open End Sub ... |
| 08.11.2001, 22:59 |
3 fields into 1
Если поле уже существует в таблице то просто сделать : update table_name set target_column= column_a+column_b+column_c -- соответственно нужные колонки where ... конечно можно включить всякие доп куски типа ',' или т.п... ... |
| 08.11.2001, 23:33 |
start [/forum/topic.php?fid=46&gotonew=1&tid=1825064]: |
64ms |
34ms |
| others: | 238ms |
| total: | 379ms |
