Версия sp
Можно-ли узнать версию установленного сервис-пака на SQL-сервере ??? ... |
| 27.11.2001, 10:32 |
Версия sp
"To identify which version of SQL Server 2000 you have installed, type SELECT @@VERSION at the command prompt when using the osql or isql utilities or in the Query window in SQL Query Analyzer. The following table shows the relationship between the version string reported by @@VERSION and the SQL Server 2000 version number. @@VERSION SQL Server 2000 version 8.00.194 SQL Server 2000 RTM 8.00.384 Database Components SP1 If you are not sure which edition of SQL Server 2000 you are running, view the last line of output returned by SELECT @@VERSION: Desktop Engine on Windows NT 5.0 (Build 2195: Service Pack 1) Enterprise Evaluation Edition on Windows NT 5.0 (Build 2195: Service Pack 1) Developer Edition on Windows NT 5.0 (Build 2195: Service Pack 1) Personal Edition on Windows NT 5.0 (Build 2195: Service Pack 1) Standard Edition on Windows NT 5.0 (Build 2195: Service Pack 1) Enterprise Edition on Windows NT 5.0 (Build 2195: Service Pack 1)" ... |
| 27.11.2001, 10:37 |
start [/forum/topic.php?fid=46&gotonew=1&tid=1824830]: |
182ms |
29ms |
| others: | 239ms |
| total: | 501ms |
