Как c помощью UPDATE обновить только первую встретившуюся запись ?
Как c помощью UPDATE обновить только первую встретившуюся запись ? ... |
| 25.12.2001, 10:03 |
"SET ROWCOUNT Causes Microsoft® SQL Server™ to stop processing the query after the specified number of rows are returned. The setting of the SET ROWCOUNT option is ignored for INSERT, UPDATE, and DELETE statements against remote tables and local and remote partitioned views . The ROWCOUNT option has no effect on dynamic cursors, but it limits the rowset of keyset and insensitive cursors. " ... |
| 25.12.2001, 10:09 |
start [/forum/topic.php?fid=46&gotonew=1&tid=1824491]: |
180ms |
53ms |
| others: | 221ms |
| total: | 510ms |
