DTS
Ya ispolsyu code nishe v DTS pakage. Po kakoito prichine na deklarazii peremennuh ya polychau oshibky. Pochemy? ---------------------------------------- Dim K As Integer Dim T As String K = 0 T = DTSSourse("Test") If Len(T) < 10 Then For K = 1 To 10 If Len(T) = 10 Then Exit For End If T = "0" & T Next K DTSDestination("Test")= T End If ... |
| 03.01.2002, 20:05 |
DTS
Была ошибка синтаксиса VB для Dim и Next. Вот так должно работать. --------------------------- Dim K Dim T K = 0 T = DTSSourse("Test") If Len(T) < 10 Then For K = 1 To 10 If Len(T) = 10 Then Exit For End If T = "0" & T Next DTSDestination("Test")= T End If ... |
| 03.01.2002, 22:46 |
start [/forum/topic.php?fid=46&gotonew=1&tid=1824430]: |
68ms |
42ms |
| others: | 239ms |
| total: | 410ms |
