Вопрос по sp_executesql
Ребята, в чем глюк. exec sp_executesql N'insert into table_name (column) values(value)' Все нормально, а если так: declare @tblname varchar(15) set @tblname = 'table_name' exec sp_executesql N'insert into '+ @tblname +' (column) values(value)' или declare @sQuery varchar(255) set @sQuery = N'insert into tablse_name (column) values(value)' exec sp_executesql @sQuery ошибка. ??? С уважением, Саша. ... |
| 23.01.2002, 07:14 |
BOL - Transact-SQL Reference - System Stored Procedures - sp_executesql "sp_executesql [@stmt =] stmt[{,[@params =] N'@parameter_name data_type [,...n]' }{,[@param1 =] 'value1' [,...n] } ] Arguments [@stmt =] stmt Is a Unicode string containing a Transact-SQL statement or batch. stmt must be either a Unicode constant or a variable that can be implicitly converted to ntext. More complex Unicode expressions (such as concatenating two strings with the + operator) are not allowed. Character constants are not allowed. If a constant is specified, it must be prefixed with an N. For example, the Unicode constant N'sp_who' is legal, but the character constant 'sp_who' is not. The size of the string is limited only by available database server memory" Надо так declare @sQuery nvarchar(255) set @sQuery = N'insert into tablse_name (column) values(value)' exec sp_executesql @sQuery ... |
| 23.01.2002, 07:36 |
start [/forum/topic.php?fid=46&gotonew=1&tid=1824216]: |
163ms |
40ms |
| others: | 232ms |
| total: | 471ms |
