что делать
если в СКЛ Сервер какой нибудь отладчик синтаксический ошибок..... просто замудохался искать причину ошибки.... ... |
| 06.02.2002, 11:34 |
что делать
1. Query Analyzer 2. "SET PARSEONLY Checks the syntax of each Transact-SQL statement and returns any error messages without compiling or executing the statement . Syntax SET PARSEONLY { ON | OFF } Remarks When SET PARSEONLY is ON, Microsoft® SQL Server™ only parses the statement. When SET PARSEONLY is OFF, SQL Server compiles and executes the statement. The setting of SET PARSEONLY is set at parse time and not at execute or run time. Do not use PARSEONLY in a stored procedure or a trigger. SET PARSEONLY returns offsets if the OFFSETS option is ON and no errors occur." ... |
| 06.02.2002, 11:41 |
start [/forum/topic.php?fid=46&gotonew=1&tid=1824035]: |
144ms |
43ms |
| others: | 200ms |
| total: | 429ms |
