Query Performance
pomogite novichky ! est" SP kotoraia zapiciviet resyl'tat query v #Temp table ( ia delay paging ) a pootm resyl"tati vibiraytcia iz #Temp table v zavicimocti ot nomera stranici voproc : kak optimizirovat" ? zapic' v #Temp table i pocledyushui select iz nego ( v #Temp table est pole identity - clustered index ) zamedliayt vcu SP ochen" medlenno rabotaet pomogite pls !!!! ... |
| 15.02.2002, 20:27 |
Query Performance
Проще было бы если бы Вы показали текст. Если не know-how. Я сталкивался со случаями, когда наличие индекса по временной таблице снижало производительность. ... |
| 16.02.2002, 06:39 |
Query Performance
vot chto y menia proicxodit : 1) CREATE TABLE [dbo].[#Temp_search1] ( [ID] [int] IDENTITY (1, 1) , [rank] [int] NULL , ] [varchar] (300) , ID] [int] not null , [Metadatas] [text] , [Autors] [char] (10) , [Titre] [varchar] (350) , [Filesize] [int] NULL , [concepts] [text] , [resume] [text] , [ModifDate] [varchar] (50) , [ContentCache] [text] , [Occurance_1] [int] , [Occurance_2] [int] , [Occurance_3] [int] , [Occurance_4] [int] ) 2) insert into #Temp_search1 ( rank , url , urlid , metadatas , autors , titre , filesize , concepts , resume , modifdate , contentcache , occurance_1 , occurance_2 , occurance_3 , occurance_4 ) SELECT rank , url, urlid, Metadatas, autors , titre, filesize, concepts, resume, modifdate , contentcache , Occurance_1 = ( select sum(dbo.fcount(Newprinfo.text_chunk ,'paiement de facture' ) ) from newprinfo where newprinfo.urlid = FT_TBL.UrlID group by newprinfo.urlid ) , Occurance_2= ( select sum(dbo.fcount(Newprinfo.text_chunk ,'guichet automatique ' ) ) from newprinfo where newprinfo.urlid = FT_TBL.UrlID group by newprinfo.urlid ) , Occurance_3= ( select sum(dbo.fcount(Newprinfo.text_chunk ,'facture au guichet automatique' ) ) from newprinfo where newprinfo.urlid = FT_TBL.UrlID group by newprinfo.urlid ) , Occurance_4= ( select sum(dbo.fcount(Newprinfo.text_chunk ,'paiement de facture au guichet automatique' ) ) from newprinfo where newprinfo.urlid = FT_TBL.UrlID group by newprinfo.urlid ) FROM url AS FT_TBL, containstable(url, contentlemmes,'ISABOUT("paiement de facture" weight (1.0) , "paiement de facture au guichet automatique" weight (1.0), "facture au guichet automatique" weight (1.0) ,"guichet automatique" weight (1.0) )') AS KEY_TBL WHERE FT_TBL.UrlID = KEY_TBL.[KEY] AND url like '%fr%' ORDER BY occurance_1 desc ,occurance_2 desc ,occurance_3 desc, occurance_4 desc 3) zaklychitel"naia viborka is #Temp_search i paging : SELECT ID , rank,url ,UrlID,Metadatas ,Autors,Titre ,Filesize,concepts,resume,ModifDate,ContentCache ,Occurance_1 , occurance_2 , Occurance_3 ,occurance_4 , MoreRecords = ( SELECT COUNT(id) FROM #Temp_search1 TI WHERE TI.ID >= @LastRec ) FROM #Temp_search1 WHERE ID > @FirstRec AND ID < @LastRec vce rabotaet ochen' medlenno , poriadka 1 min a nado pobistree ne podkashete kak optimisirovat" ???? ... |
| 18.02.2002, 15:20 |
Query Performance
Попробуйте избавиться от вызова функции fcount либо радикально сократить количество её вызовов. Судя по структуре запроса, сделать это можно. В MS SQL вызов функций работает ОЧЕНЬ МЕДЛЕННО. Тормозит, скорее всего именно он. Удачи. ... |
| 18.02.2002, 16:26 |
Query Performance
2 Воблин: "вызов функций работает ОЧЕНЬ МЕДЛЕННО" - вызов любых функций, или "ОЧЕНЬ МЕДЛЕННЫХ" ? Можно поподробнее? ... |
| 18.02.2002, 17:57 |
Query Performance
ia protestirovala c function i bez nee raznici pochti net ( 2 ces ) ... |
| 18.02.2002, 18:01 |
Query Performance
1. Попробуйте заменить вр.таблицы на таблицы-переменные(если объёмы не гигантские) 2. На мой взгляд тормозят вложенные запросы. Попробуйте написать без них, используя group by и еще одну вр. таблицу (или таблицу-переменную) ... |
| 19.02.2002, 06:53 |
start [/forum/topic.php?fid=46&gotonew=1&tid=1823855]: |
158ms |
45ms |
| others: | 208ms |
| total: | 460ms |
