подлый вопрос от brainbench
Добрый день, господа профессионалы! помогите мне плз с ответами на Эти вопросы по MS SQL Server 7 Administration (их автор это тупой brainbench) потому что я просто все уже перерыла и Microsoft SQL Server Books Online и MSDN: Вопрос № 1: Scenario You are using transactional replication to move data from a central server to multiple subscribers. Some of the subscribers are allowed to update the publisher as well as themselves. In the scenario above, what Net-Library protocol must the subscribers use through the Microsoft Distributed Transaction Coordinator to accomplish this task? Choice 1 IPX/SPX Choice 2 PPP Choice 3 TCP/IP Choice 4 Multiprotocol Choice 5 Named Pipes Вопрос №2: In the event of a failure of a backup job, how can you notify the three backup administrators with the least amount of administrative effort? Choice 1 Create three alerts, one for each administrator. Choice 2 Create a single job that sends three notifications. Choice 3 Create a trigger that will send an e-mail a trigger to the three administrators. Choice 4 Create an operator using a distribution list for the e-mail address. Choice 5 Create three jobs, one for each administrator. -------------------------------------------- Огромное спасибо всем ответившим Дарья ... |
| 12.03.2002, 03:11 |
Для второго ответ номер 3 Для первого я бы выбрал Miliprotocol TCP/IP ... |
| 12.03.2002, 06:37 |
IMHO Вопрос №2: In the event of a failure of a backup job , how can you notify the three backup administrators with the least amount of administrative effort ? Choice 1 Create three alerts, one for each administrator. 3 alert-а, значит 3 operator-а и 3 привязки. Многовато административных усилий. НЕТ Choice 2 Create a single job that sends three notifications. И как второй job узнает о результатах работы первого job-а ? НЕТ Choice 3 Create a trigger that will send an e-mail a trigger to the three administrators. Триггер на job ? Это что-то новенькое. НЕТ Choice 4 Create an operator using a distribution list for the e-mail address. Один оператор, использующий список рассылки это IMHO то, что надо. ДА Choice 5 Create three jobs, one for each administrator. Три job-а - это многовато для "least amount of administrative effort". НЕТ ... |
| 12.03.2002, 07:18 |
Да - да триггер на job а вернее на msdb.sysjobhistorys где status = 0 ( т.е. ошибка при выполнении ) ... |
| 12.03.2002, 07:45 |
Большое спасибо To: Glory Я тоже так думала, что Choice 4, но в Enterprise Manager -> мой Server -> папка Management -> Job -> JobProperties -> закладка Notifications (Actions to perform when the Job completes)там можно выбрать только одного оператора (E-mail operator) причем, даже если я для нескольких операторов выбираю в их свойствахз (закладка Notifications) Jobs и помечаю эти задания, от которых этому оператору надо послать оповещение, то все равно это задание можно пометить только для одного оператора. В чем же дело? Я в группе sysadmin ... |
| 12.03.2002, 12:59 |
Зато в установках конкретного оператора можно выбрать оповещение ни на один адрес а на группу то бишь distribution list. Enterprise Manager -> мой Server -> папка Management -> SQL Server Agent -> Operators -> конкретный Operator -> Properties -> E-mail name ... А если группы рассылки еще и берутся с Exchange Server-a, то вообще красота ... |
| 12.03.2002, 13:13 |
To: Glory Понятно, то есть надо чтобы был доступен Exchange или другой почтовый сервер. Благодарю ... |
| 12.03.2002, 14:02 |
Понятно, то есть надо чтобы был доступен Exchange или другой почтовый сервер. вовсе нет. Группы рассылки могут создаваться и в Local Address Book. Кроме того для конкретного оператора адреса оповещения могут быть просто перечислены через ; в настройках ... |
| 12.03.2002, 14:07 |
start [/forum/topic.php?fid=46&gotonew=1&tid=1823593]: |
185ms |
62ms |
| others: | 234ms |
| total: | 536ms |
