С DBF на SQL выдается ошибка
При загрузке данных в SQL версию при создании индексов Справочник.Номенклатура выдается след.ошибка: SQL State: 23000 Native: 1505 Message: [Microsoft][ODBC SQL Server Driver][SQL Server]CREATE UNIQUE INDEX terminated because a duplicate key was found. Most significant primary key is " 3SGБЦО ".Что написано понимаю, а вот что делать не знаю.Подскажите, пжлста. ... |
| 10.04.2002, 12:35 |
Error 1505 Severity Level 14 Message Text CREATE UNIQUE INDEX terminated because a duplicate key was found for index ID %d. Most significant primary key is '%S_KEY'. Explanation This error occurs when you attempt to create a unique index and more than one row contains the duplicate value. Microsoft® SQL Server™ has detected a uniqueness violation and cancels the CREATE INDEX operation. For example, the creation for the index below would be canceled due to the uniqueness violation at row 3. The BUCHANAN STEVEN combination is already located in row 1. TABLE: tblTest Row strLastName strFirstName strCity strState 1 BUCHANAN STEVEN BOISE ID 2 SUYAMA MICHAEL BUTTE MT 3 BUCHANAN STEVEN SEATTLE WA 4 DAVOLIO NANCY SAN FRANCISCO CA CREATE UNIQUE NONCLUSTERED INDEX idxUniqueNames ON tblText(strLastName, strFirstName) Action You must review your index objective. If your index does not need to be unique, remove the UNIQUE keyword and reissue the CREATE INDEX statement. However, if you still want to create a unique index, you must query the table in question and remove the rows in error. For more information about the CREATE INDEX statement, see CREATE INDEX. To find the duplicate rows, issue a GROUP BY statement: SELECT strLastName, strFirstName, count(*) as cnt FROM tblTest GROUP BY strLastName, strFirstName HAVING count(*) > 1 ... |
| 10.04.2002, 15:21 |
start [/forum/topic.php?fid=46&gotonew=1&tid=1823159]: |
145ms |
47ms |
| others: | 205ms |
| total: | 436ms |
