Помогите с восстановлением таблички
Проблема: после отключения электричества к табличке нельзя обратиться ни через один запрос хотя через Интерпрайз я ее могу видеть при обращении через запрос он выдает: Attempt to fetch logical page (1:2466) ... |
| 27.04.2002, 10:40 |
DBCC CHECKTABLE DBCC CHECKDB ... |
| 27.04.2002, 10:56 |
Вот что он мне ответил а как их исправить ???????? Server: Msg 2533, Level 16, State 1, Line 1 Table error: Page (1:2466) allocated to object ID 1125579048, index ID 0 was not seen. Page may be invalid or have incorrect object ID information in its header. Server: Msg 2533, Level 16, State 1, Line 1 Table error: Page (1:2467) allocated to object ID 1125579048, index ID 0 was not seen. Page may be invalid or have incorrect object ID information in its header. Server: Msg 2533, Level 16, State 1, Line 1 Table error: Page (1:246 allocated to object ID 1125579048, index ID 0 was not seen. Page may be invalid or have incorrect object ID information in its header. Server: Msg 2533, Level 16, State 1, Line 1 Table error: Page (1:2469) allocated to object ID 1125579048, index ID 0 was not seen. Page may be invalid or have incorrect object ID information in its header. Server: Msg 2533, Level 16, State 1, Line 1 Table error: Page (1:2470) allocated to object ID 1125579048, index ID 0 was not seen. Page may be invalid or have incorrect object ID information in its header. Server: Msg 2533, Level 16, State 1, Line 1 Table error: Page (1:2471) allocated to object ID 1125579048, index ID 0 was not seen. Page may be invalid or have incorrect object ID information in its header. DBCC results for 'T_Main_res'. There are 102089 rows in 4350 pages for object 'T_Main_res'. CHECKTABLE found 0 allocation errors and 6 consistency errors in table 'T_Main_res' (object ID 112557904. repair_allow_data_loss is the minimum repair level for the errors found by DBCC CHECKTABLE (Expeditor.dbo.T_Main_res ). ... |
| 27.04.2002, 12:03 |
Для начала все таки попробуйте DBCC CHECKTABLE ('Expeditor.dbo.T_Main_res', REPAIR_FAST ) если не поможет, то DBCC CHECKTABLE ('Expeditor.dbo.T_Main_res', REPAIR_ALLOW_DATA_LOSS ) но, как видите из названия ключа, последний вариант может привести к потери некоторых данных ... |
| 27.04.2002, 12:21 |
Спасибо Glory ваши советы как всегда на высоте Voland ... |
| 27.04.2002, 12:31 |
start [/forum/topic.php?fid=46&gotonew=1&tid=1822909]: |
146ms |
27ms |
| others: | 207ms |
| total: | 412ms |
