Установка сервера
Люди, помогите установить SQL-Server desktop на 98 windows как сервер для локальной работы! В конце установки, когда все файлы скопированы, при содинении Configuring Server... Starting service... Connect to Server... Failed... Retrying. Setup fail to configure the server Refer to te server error logs for more information. Потом все что было скопировано удаляется, кроме логов: -----------------------------------------------errorlog--------------- 2002-05-14 22:34:16.88 kernel Microsoft SQL Server 7.00 - 7.00.623 (Intel X86) Nov 27 1998 22:20:07 Copyright (c) 1988-1998 Microsoft Corporation Developer Edition on Windows 4.10 (Build 2222: A ) 2002-05-14 22:34:17.09 kernel Copyright (C) 1988-1997 Microsoft Corporation. 2002-05-14 22:34:17.12 kernel All rights reserved. 2002-05-14 22:34:17.14 kernel Logging SQL Server messages in file 'f:\MSSQL7_data\log\ERRORLOG'. 2002-05-14 22:34:17.28 kernel initconfig: Number of user connections limited to 32767. 2002-05-14 22:34:17.33 kernel SQL Server is starting at priority class 'normal'(1 CPU detected). 2002-05-14 22:34:17.54 kernel User Mode Scheduler configured for thread processing 2002-05-14 22:34:18.71 server Directory Size: 2559 2002-05-14 22:34:18.81 spid1 Using dynamic lock allocation. [500] Lock Blocks, [1000] Lock Owner Blocks 2002-05-14 22:34:18.87 spid1 failed to get sqlservr image range 2002-05-14 22:34:18.91 spid1 Warning ****************** 2002-05-14 22:34:18.94 spid1 SQL Server started in single user mode. Updates allowed to system catalogs. 2002-05-14 22:34:18.97 spid1 Warning ****************** 2002-05-14 22:34:18.99 spid1 Recovering only master database 2002-05-14 22:34:19.05 spid1 Starting up database 'master'. 2002-05-14 22:34:19.08 spid1 Opening file f:\MSSQL7_data\data\master.mdf. 2002-05-14 22:34:19.22 spid1 Opening file f:\MSSQL7_data\data\mastlog.ldf. 2002-05-14 22:34:19.44 spid1 Loading SQL Server's Unicode collation. 2002-05-14 22:34:19.54 spid1 Loading SQL Server's non-Unicode sort order and character set. 2002-05-14 22:34:19.92 spid1 4 transactions rolled forward in database 'master' (1). 2002-05-14 22:34:19.96 spid1 0 transactions rolled back in database 'master' (1). 2002-05-14 22:34:20.28 spid1 Server is unnamed. 2002-05-14 22:34:20.31 kernel Using 'SQLEVN70.DLL' version '7.00.623'. 2002-05-14 22:34:20.36 kernel Using 'OPENDS60.DLL' version '7.00.00.0623'. 2002-05-14 22:34:20.45 ods Using 'SSMSSH70.DLL' version '7.0.623' to listen on ''. 2002-05-14 22:34:20.55 spid1 SQL Server's Unicode collation is: 2002-05-14 22:34:20.58 spid1 'English' (ID = 1033). 2002-05-14 22:34:20.60 spid1 comparison style = 196609. 2002-05-14 22:34:20.62 spid1 SQL Server's non-Unicode sort order is: 2002-05-14 22:34:20.64 spid1 'nocase_iso' (ID = 52). 2002-05-14 22:34:20.67 spid1 SQL Server's non-Unicode character set is: 2002-05-14 22:34:20.69 spid1 'iso_1' (ID = 1). 2002-05-14 22:34:20.76 kernel Warning: override, autoexec procedures skipped. 2002-05-14 22:36:11.89 kernel SQL Server is terminating due to 'stop' request from Service Control Manager. --------------------------------------------------------------------------------------- --------------------------------------------cnfgsvr.out Starting Service ... Connecting to Server ... driver={sql server};server=IN;UID=sa;PWD=;database=master [Microsoft][ODBC SQL Server Driver][Shared Memory]SQL Server does not exist or access denied. [Microsoft][ODBC SQL Server Driver][Shared Memory]ConnectionOpen (Connect()). driver={sql server};server=IN;UID=sa;PWD=;database=master [Microsoft][ODBC SQL Server Driver][Shared Memory]SQL Server does not exist or access denied. [Microsoft][ODBC SQL Server Driver][Shared Memory]ConnectionOpen (Connect()). driver={sql server};server=.;UID=sa;PWD=;database=master [Microsoft][ODBC SQL Server Driver][Named Pipes]SQL Server does not exist or access denied. [Microsoft][ODBC SQL Server Driver][Named Pipes]ConnectionOpen (Connect()). SQL Server configuration failed. ... |
| 14.05.2002, 18:50 |
Установка сервера
Установите компонент Windows 98 "Удаленный доступ к сети": Установка и удаление программ -- Установка Windows -- Связь -- Удаленный доступ к сети И ВСЁ! ЛИШНЕГО НЕ ДОБАВЛЯЙТЕ (вроде фальш-сетевухи). Если всё это уже установлено, тогда не знаю. ... |
| 14.05.2002, 22:16 |
Установка сервера
К сожалению - это уже установлено, а больше ничего особенного не добавлено ... |
| 15.05.2002, 05:05 |
Установка сервера
Тогда добавьте ("Панель управления" >> "Сеть"): 1)сетевую плату (любую, из базы драйверов Windows) 2)протокол: TCP/IP 3)клиента: клиент для сетей Microsoft (и способ входа в сеть) Во вкладке "Идентификация" подберите красивое имя для Вашей машины (так же будет называться SQL Server(если станет)) ... |
| 15.05.2002, 16:19 |
Установка сервера
Лучше не любую плату, а специальную заглушку "Loop Back Adapter" - кажется называется в списка драйверов Microsoft, в Русской версии это "Адаптер Microsoft замыкания на себя". ... |
| 16.05.2002, 08:05 |
Установка сервера
ДОрогие! с вами я продвинулась немного дальше. Но адаптер замыкания не нашла, но установила другой, тож микрософтовский. Вот что вышло: Configuring Server... Starting servis... Connect to Server... Remapping ... disconnect from server... starting service... connecting to server... reindexing server... хлоп! сбой (или перезагрузка, или зависание) Все, бросать мне это дело? на работе хорошо установилось (но там есть сетевая карта). А win2000, боюсь моя машинка не вытянет (64М). ЧТо делать, а? ... |
| 16.05.2002, 20:43 |
Установка сервера
1)гарантирую, что физическое наличие сетевухи необязательно (100%) 2)именно LOOPBACK вовсе необязателен (100%) 3)чудесно станет и на 32Mb (100%) 4)дело это не бросайте 5)дайте время подумать ... |
| 16.05.2002, 20:53 |
Установка сервера
Жду, очень сильно! Раньше(до того, как написала сюда), даже без этих установок драйверов, у меня доходило до этого реиндекса (я уже раз 20 пробовала, с разными изменениями - при этом удаляя ашампунем после установки). Виндоус чист - только что переустановлен. Один раз - оно дошло до конца, но при этом реиндексе вдруг засветился синий экран (чес слово не помню - что было написано), но после нажатия любой клавиши - все дошло до конца. А после перезагрузки, при попытке запустить сервер - недопустимая операция. Вот. Я уже боюсь, что мне и win2000 не поможет, хотя диск - вон , уже на готове лежит. Жду Мне в понедельник работать начинать надоооо ... |
| 16.05.2002, 21:03 |
Установка сервера
1)хотел предложить поснимать флажки в Автозагрузке, но раз винда чистая, то снимать, видимо, нечего... 2)чудесно станет и на винду 98 (даже не SE) 3)попробуйте добавить службу: служба доступа к файлам и принтерам сетей Microsoft 4)уберите все лишние протоколы (если есть), оставьте только TCP/IP 5)поставьте плату 3Com >> первую в списке 6)назначьте IP адрес (для платы): 192.168.0.1 подмаска: 255.255.255.0 ... |
| 16.05.2002, 21:17 |
Установка сервера
Before Reinstalling SQL Server 7.0 After a Failed Install, Delete the Following Registry Entries: HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Services\MSSQLServer HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Services\SQLServerAgent HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\MSSQLServer HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Microsoft SQL Server 7 HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\MSSQLServ70 and delete the target installation directory (C:\MSSQL7 by default). ... |
| 16.05.2002, 23:39 |
Установка сервера
Установила 2000 - на Remapping... погас экран, насовсем. У меня тут же тоже погасло внутри. ... |
| 18.05.2002, 18:04 |
Установка сервера
Имела ввиду windows2000 и сервер 7 ... |
| 18.05.2002, 18:07 |
start [/forum/topic.php?fid=46&gotonew=1&tid=1822703]: |
182ms |
37ms |
| others: | 215ms |
| total: | 472ms |
