Как вызвать из Access 97 хранимую процедуру SQL 2000?
Подскажите, плиз, как вызвать из Access 97 хранимую процедуру SQL 2000? ... |
| 22.05.2002, 16:21:23 |
Function Execute_Passthrough_Query(sqltext As String) ' Purpose: Run a temporary pass-through query. ' Accepts: sqltext: SQL string to run or stored procedure's name. ' Returns: nothing. Dim dbSQL As Database, qdSQL As QueryDef Dim strConnect As String Dim strCommand As String strConnect = "ODBC;DRIVER=SQL Server;SERVER=LIBNT4NAS02;DATABASE=test_soldb;Trusted_Connection=Yes" Set dbSQL = DBEngine.Workspaces(0).Databases(0) ' Create a temporary QueryDef object that is not saved. Set qdSQL = dbSQL.CreateQueryDef("") ' Set the ReturnsRecords property to False in order to use the ' Execute method. qdSQL.ReturnsRecords = False qdSQL.Connect = strConnect qdSQL.SQL = sqltext qdSQL.Execute qdSQL.Close Set qdSQL = Nothing dbSQL.Close Set dbSQL = Nothing End Function ... |
| 22.05.2002, 21:46:09 |
Function Passthrough_Query(strSQL As String) As Recordset ' Purpose: Run pass-through query. ' Accepts: strSQL: stored procedure's name. ' Returns: resultset. Dim dbSQL As Database Dim strConnect As String strConnect ="ODBC;DRIVER=SQL Server;SERVER=LIBNT4NAS02;DATABASE=pubs;Trusted_Connection=Yes" Set dbSQL = DBEngine.Workspaces(0).OpenDatabase("", False, False, strConnect) Set Passthrough_Query = dbSQL.OpenRecordset(strSQL, dbOpenSnapshot, dbSQLPassThrough) End Function Private Sub Command1_Click() Dim rsResult As Recordset Dim strSQL as String strSQL="exec my_stored_procedure_name" Set rsResult = Passthrough_Query(strSQL).OpenRecordset End Sub ... |
| 22.05.2002, 21:56:45 |
start [/forum/topic.php?fid=46&gotonew=1&tid=1822623]: |
182ms |
42ms |
| others: | 206ms |
| total: | 481ms |
