Fast Algorithm for calculation Max simultaneous calls in telephony network
Nujen Sovet kak bistro bi4islit MAX kol-vo odnovremenno zvonjashiz v telefonnoy seti. Vi4islenija s resolution 1 sec. Max calls output dlya 1 hour Input table Original_tbl mojet bit o4en bolshaja ( 1 000 000 rows and more) Ja napisal script pabotaet pravilno no ne goditsja dlya Huge data Zaranee spasibo Fields from Original_tbl table : NW_ID : Telephone Network Col011: Start Call Time Col012: Start Call Date Col013: End Call Time Col014: End Call Date NW_ID Col011 Col012 Col013 Col014 ----------- --------- ----------- --------- ----------- 88 10:47:02 15/11/2001 10:47:07 15/11/2001 88 10:46:21 15/11/2001 10:46:46 15/11/2001 88 10:48:43 15/11/2001 10:48:43 15/11/2001 88 10:53:06 15/11/2001 10:54:11 15/11/2001 88 10:47:56 15/11/2001 10:49:10 15/11/2001 88 10:28:33 15/11/2001 10:44:14 15/11/2001 88 10:55:44 15/11/2001 10:57:56 15/11/2001 -------------------------------------------------------- CREATE FUNCTION fn_GetAllDateTime( @NW_ID INT, @StartCallDateTime DateTime, @EndCallDateTime DateTime) RETURNS @AllDateTimeTable TABLE ( NW_ID int NOT NULL, Dt_Hr_Min_Sec DateTime NOT NULL ) AS BEGIN DECLARE @RunCallDateTime DateTime SET @RunCallDateTime = @StartCallDateTime WHILE @RunCallDateTime BETWEEN @StartCallDateTime AND @EndCallDateTime BEGIN INSERT INTO @AllDateTimeTable SELECT @NW_ID,@RunCallDateTime SET @RunCallDateTime = DATEADD(ss,1,@RunCallDateTime) END RETURN END ---------------------------------------------------------- DECLARE @MinStartCallDateTime DATETIME DECLARE @MaxEndCallDateTime DATETIME -- ja chotel zasunut kod v UDF poetomu -- ne polzovalsja SET DATETIMEFORMATE SELECT @MinStartCallDateTime = MIN(CAST(SubString(Col012,7,4)+ SubString(Col012,4,2) + SubString(Col012,1,2)+' '+ LTRIM(RTRIM(Col011)) as DateTime)) , @MaxEndCallDateTime = MAX(CAST(SubString(Col014,7,4)+ SubString(Col014,4,2) + SubString(Col014,1,2)+' '+ LTRIM(RTRIM(Col013)) as DateTime)) FROM Original_tbl WHERE NW_ID = 88 SELECT NW_ID, CAST (CONVERT(VARCHAR(12),Dt_Hr_Min_Sec,103) AS SMALLDATETIME) Dt, DATEPART(hh, Dt_Hr_Min_Sec) as Hr, MAX(Max_Sim_Calls) AS Max_Active_Calls FROM (SELECT fn_G.NW_ID,fn_G.Dt_Hr_Min_Sec,Count(Org.NW_ID) AS Max_Sim_Calls FROM [dbo].[fn_GetAllDateTime](88,@MinStartCallDateTime,@MaxEndCallDateTime) fn_G, Original_tbl Org WHERE Org.NW_ID = 88 AND Dt_Hr_Min_Sec BETWEEN CAST(SubString(Col012,7,4)+ SubString(Col012,4,2) + SubString(Col012,1,2)+' '+ LTRIM(RTRIM(Col011)) as DateTime) AND CAST(SubString(Col014,7,4)+ SubString(Col014,4,2) + SubString(Col014,1,2)+' '+ LTRIM(RTRIM(Col013)) as DateTime) GROUP BY fn_G.NW_ID,fn_G.Dt_Hr_Min_Sec) aaa GROUP BY NW_ID, CAST (CONVERT(VARCHAR(12),Dt_Hr_Min_Sec,103) AS SMALLDATETIME),DATEPART(hh,Dt_Hr_Min_Sec) Output : ( OUTPUT DATA NE SVJAZANA S INPUT DATA ETO TOLKO PRIMER!!!) NW_ID Dt Hr Max_Active_Calls ---------- - -------------------- ------- ----------------------- 88 2002-02-01 00:00:00 9 20 88 2002-02-01 00:00:00 10 6 ... |
| 20.04.2002, 11:19:36 |
Мне нужно небольшое уточнение: мы считаем только звонки, длящиеся в течение интервала, или целиком в него ложащиеся. Я поясню: имеем 3 звонка: 1-й начался в 0:00 и завершился в 0:45, 2-й начался в 0:30 и завершился в 1:15 и 3-й начался в 0:20 и завершился в 0:40. Сколько это означает звонков согласно Вашей задаче на интервале 0:10 - 1:10: 1 или 3? С уважением, Ивент Исаевич Вьюер ... |
| 20.04.2002, 16:15:12 |
Spasibo za projavlenniy interes Poprobuyu objasnit. V 1 hour est 3600 secunds mne nujno dlja kajdoy secund nayti kol-vo aktivnix abonentov a potom dat dlja 1 hour MAX resultat naprimer: First 1:10:15 to 1:11:30 Second 1:10:20 to 1:12:45 Eto zna4it s 1:10:20 to 1:11:30 bilo dlja kajdoy sec 2 calls i dlja 1:00:00 sootvetstvenno MAX 2 calls S uvajeniem Oleg ... |
| 20.04.2002, 16:30:24 |
А сутки считаются поделенными на 24 часовых непересекающихся отрезка, или часовое окно может скользить по суточному интервалу? Т.е. {[0:00, 1:00), [1:00, 2:00), ... } или ответом может быть, что max приходится, напр., на [0:43, 1:43)? ... |
| 20.04.2002, 19:22:41 |
V sutkax est 24 intervala , Naprimer from 1:00 to 2:00 i MAX odnovremenno zvonjashix (MAX simultaneous calls) bilo i 1:31:45 - 50 Calls. Autput budet NW_ID Dt Hr Max_Active_Calls ----- --- --- ------------------ 88 2002-02-01 1 50 Ja vprinzipe napisal script kotoriy rabotaet pravilno problema ,4to INPUT DATA o4en bolshaa (1 000 000 rows and more) Esli u kogo nibud est idey budu o4en rad uslishat S uvajeniem oleg ... |
| 21.04.2002, 04:44:59 |
Sorry, V primere iz4ezli probeli mejdu polami Itak output dlja moego primera : Date : 2002-02-01 Hr : 1 Max_Active_Calls : 50 Spasibo ... |
| 21.04.2002, 04:50:18 |
Если я правильно понял, то задачу можно переформулировать так: для произвольного интервала [dt0, dt1] .........dt0...........................dt1 .........[----|------------------------] Звонок.[------|] Звонок..[-----|--] Звонок....[---|] Звонок......[-|-----] Звонок.............[------] Звонок.................[---------] Звонок...................[---------] Звонок.......................[--] Звонок...........................[--------] определить максимальную толщину слоя активных звонков (для примера на рис. это будет 4). Предлагаю следующий простой алгоритм. Конечно, я его тестировал не на миллиарде записей, но на десятках тысяч показывает неплохую производительность. --@dt0, @dt1 - входные п-ры. Задают границы интервала. --tbl - основная таблица, в к-й вы накапливаете инф-ю по звонкам. Поля dt_callstart, dt_callend - начало и конец звонка (datetime). declare @t table (id int identity, dt datetime, n int) insert @t (dt, n) select dt_callstart, 1 from tbl where dt_callstart between @dt0 and @dt1 or dt_callend between @dt0 and @dt1 insert @t (dt, n) select dt_callend, -1 from tbl where dt_callstart between @dt0 and @dt1 or dt_callend between @dt0 and @dt1 declare @result int select @result = max(s) from (select (select sum(t2.n) from @t t2 where t2.dt <= t1.dt) as s from @t t1) as t select @result С его помощью вы можете получить макс.кол-во звонков на каждом часовом интервале для любых суток. Тем не менее, если кол-во подобных задач отчетности будет множиться, то на мой взгляд, вам следует присмотреться к Analysis Services в составе SQL Server. ... |
| 21.04.2002, 07:45:05 |
Blagodaru vas, Лука Кладбищев Vash algorithm rabotaet obsalutno pravilno Sey4as pishu UDF xo4u proverit na bolshom kol-ve Data Potom soobshu resultati Spasibo Oleg ... |
| 21.04.2002, 10:23:36 |
Dlja Лука Кладбищев Sdelal UDF iz vashego algorithma rabotaet 4ut medlennee 4em u menja bilo ranshe NO GORAZDO PROZRA4NEE Esho ras spasibo S Uvajeniem Oleg CREATE FUNCTION fn_calc_MAX_simultaneous_calls (@NW_ID INT, @dt0 DateTime, @dt1 DateTime) RETURNS INT AS BEGIN -- Example for input data --SET @NW_ID = 88 --SET @dt0 = '20020201 10:00:00' --SET @dt1 = '20020201 11:00:00' declare @t table (id int identity, dt datetime, n int) insert @t (dt, n) select CAST(SubString(Col012,7,4)+ SubString(Col012,4,2) + SubString(Col012,1,2)+' '+ LTRIM(RTRIM(Col011)) as DateTime), 1 from Original_tbl where (CAST(SubString(Col012,7,4)+ SubString(Col012,4,2) + SubString(Col012,1,2)+' '+ LTRIM(RTRIM(Col011)) as DateTime) between @dt0 and @dt1 or CAST(SubString(Col014,7,4)+ SubString(Col014,4,2) + SubString(Col014,1,2)+' '+ LTRIM(RTRIM(Col013)) as DateTime) between @dt0 and @dt1) AND NW_ID = @NW_ID insert @t (dt, n) select CAST(SubString(Col014,7,4)+ SubString(Col014,4,2) + SubString(Col014,1,2)+' '+ LTRIM(RTRIM(Col013)) as DateTime), -1 from Original_tbl where (CAST(SubString(Col012,7,4)+ SubString(Col012,4,2) + SubString(Col012,1,2)+' '+ LTRIM(RTRIM(Col011)) as DateTime) between @dt0 and @dt1 or CAST(SubString(Col014,7,4)+ SubString(Col014,4,2) + SubString(Col014,1,2)+' '+ LTRIM(RTRIM(Col013)) as DateTime) between @dt0 and @dt1) AND NW_ID = @NW_ID declare @result int select @result = max(s) from (select (select sum(t2.n) from @t t2 where t2.dt <= t1.dt) as s from @t t1) as t RETURN @result END ... |
| 22.04.2002, 04:29:35 |
Эта статья также может быть полезной: http://www.sqlmag.com/Articles/Print.cfm?ArticleID=23511 ... |
| 26.04.2002, 17:36:30 |
2Serhiy+Snisarenko Spasibo za link ja daje li4no znau avtora statii on vedet u nas "Israeli SQL and OLAP user group" ja govoru o Itzik Ben-Gan S uvajeniem Oleg ... |
| 02.05.2002, 05:58:53 |
По-моему, все гораздо проще: количество активных звонков меняется в момент начала или конца каждого звонка. Не надо считать каждую секунду! Нужно посчитать количество звонков в точках изменения! Например для определения максимальной пиковой нагрузки: /*Я заменил название колонок и таблицы для читабельности*/ /*Start и End - полные даты, - можно сделать функцией, например*/ SELECT TOP 1 MIN(c1.Start) AS [Time], /*конечно min только ради вывода - можно убрать и добавить группировку по Start */ COUNT(*) + 1 AS [Max Count] FROM call_table c1 INNER JOIN call_table c2 ON c1.CallID != c2.CallID AND c1.Start BETWEEN c2.Start AND c2.[End] GROUP BY c1.CallID ORDER BY COUNT(*) DESC Соответственно, если добавить тоже для End, то получится твоя задача: SELECT MIN(c1.Start) AS [Time], COUNT(*) AS [Active calls] FROM call_table c1 INNER JOIN call_table c2 ON c1.CallID != c2.CallID AND c1.Start BETWEEN c2.Start AND c2.[End] GROUP BY c1.CallID UNION SELECT MIN(c1.Start) AS [Time], COUNT(*) AS [Active calls] FROM call_table c1 INNER JOIN call_table c2 ON c1.CallID != c2.CallID AND c1.End BETWEEN c2.Start AND c2.[End] GROUP BY c1.CallID ORDER BY MIN(c1.Start) Вопрос в производительности... ... |
| 06.05.2002, 12:11:53 |
2tmpnick Spasobo za interes proyavlenniy k moey teme ja u sebja v programme poka realizoval to algoritmu deda mazaja ( ili luka kladbishev ja ponal eto odin i tot je 4elovek) vremja ot 30 sec do 1 min dlja dannix za 1 hour poetomu prixoditcja zapuskat job Vi pravi zada4a nayti MAX nagruzku v kajdiy 4ac i ne objazatelno s4itat dlja kajdoy sec. Ja poprobuyu ispolzovat vash algoritm i coobshu potom resultati S uvajeniem Oleg ... |
| 07.05.2002, 05:18:55 |
start [/forum/topic.php?fid=46&gotonew=1&tid=1822601]: |
191ms |
62ms |
| others: | 239ms |
| total: | 552ms |
