Peredacha procedure imja tablici
Mozhno li peredat' v proceduru imja tablici. Primer CREAT PROCEDURE @name varchar(20) AS SELECT * FROM @name ... |
| 02.07.2002, 15:28:01 |
create procedure @object varchar(20) as begin Declare @sql varchar(120) set @sql = 'select * from ' + @object exec (@sql) end ... |
| 02.07.2002, 15:40:40 |
Spasibo ... |
| 02.07.2002, 16:04:47 |
start [/forum/topic.php?fid=46&gotonew=1&tid=1822048]: |
52ms |
42ms |
| others: | 220ms |
| total: | 360ms |
