Bulk Insert Task
Gde moshno vsyat obrasez napisaniya Bulk Insert Task v SQL 2000? ... |
| 16.07.2002, 18:37:06 |
Bulk Insert Task
Examples This example imports order detail information from the specified data file using a pipe (|) as the field terminator and |\n as the row terminator. BULK INSERT Northwind.dbo.[Order Details] FROM 'f:\orders\lineitem.tbl' WITH ( FIELDTERMINATOR = '|', ROWTERMINATOR = '|\n' ) This example specifies the FIRE_TRIGGERS argument. BULK INSERT Northwind.dbo.[Order Details] FROM 'f:\orders\lineitem.tbl' WITH ( FIELDTERMINATOR = '|', ROWTERMINATOR = ':\n', FIRE_TRIGGERS ) ... |
| 16.07.2002, 18:43:49 |
Bulk Insert Task
Mne nado kak eto ispolsovat v DTS. V SQL 2000 est' novui Bulk Insert task. ... |
| 16.07.2002, 23:05:25 |
start [/forum/topic.php?fid=46&gotonew=1&tid=1821764]: |
48ms |
27ms |
| others: | 204ms |
| total: | 310ms |
