Помогите понять, что за ошибки и как их убрать?
Настроил автоматический backup, но выполняется с ошибками, как их убрать? Не помешают ли они восстановлению на эту или другую машину? Microsoft (R) SQLMaint Utility (Unicode), Version Logged on to SQL Server 'YELLOWPAGES' as 'NT AUTHORITY\SYSTEM' (trusted) Starting maintenance plan 'DB Yellowpages_1' on 06.05.2002 23:25:10 Database chizhsite: Check Data and Index Linkage... ** Execution Time: 0 hrs, 0 mins, 2 secs ** [Microsoft SQL-DMO (ODBC SQLState: 42000)] Error 5058: [Microsoft][ODBC SQL Server Driver][SQL Server]Option 'SINGLE_USER' cannot be set in database 'MASTER'. [Microsoft][ODBC SQL Server Driver][SQL Server]sp_dboption command failed. Database master: Check Data and Index Linkage... [Microsoft SQL-DMO (ODBC SQLState: 42000)] Error 7919: [Microsoft][ODBC SQL Server Driver][SQL Server]Repair statement not processed. Database needs to be in single user mode. The following errors were found: [Microsoft][ODBC SQL Server Driver][SQL Server]Repair statement not processed. Database needs to be in single user mode. ** Execution Time: 0 hrs, 0 mins, 1 secs ** Database model: Check Data and Index Linkage... ** Execution Time: 0 hrs, 0 mins, 1 secs ** [Microsoft SQL-DMO (ODBC SQLState: 42000)] Error 5070: [Microsoft][ODBC SQL Server Driver][SQL Server]Database state cannot be changed while other users are using the database 'msdb' [Microsoft][ODBC SQL Server Driver][SQL Server]ALTER DATABASE statement failed. [Microsoft][ODBC SQL Server Driver][SQL Server]sp_dboption command failed. Database msdb: Check Data and Index Linkage... [Microsoft SQL-DMO (ODBC SQLState: 42000)] Error 7919: [Microsoft][ODBC SQL Server Driver][SQL Server]Repair statement not processed. Database needs to be in single user mode. The following errors were found: [Microsoft][ODBC SQL Server Driver][SQL Server]Repair statement not processed. Database needs to be in single user mode. ** Execution Time: 0 hrs, 0 mins, 1 secs ** [5] Database Northwind: Check Data and Index Linkage... ** Execution Time: 0 hrs, 0 mins, 3 secs ** [6] Database pubs: Check Data and Index Linkage... ** Execution Time: 0 hrs, 0 mins, 1 secs ** [7] Database yellow page: Check Data and Index Linkage... ** Execution Time: 0 hrs, 0 mins, 3 secs ** Спасибо. ... |
| 07.05.2002, 15:07:02 |
А как Вы базу переводите в однопользовательский режим доступа? ... |
| 07.05.2002, 16:01:02 |
Из сообщений я понял что в автоматический backup Вы включили БД master и msdb Вот Вам цитата из BOL: Only a full database backup can be performed on the master database. От себя добавлю: для msdb - full and differential database backup can be performed а что уж вы там делаете в Вашем автоматическом backup одному Вам известно C уважением,Snake ... |
| 08.05.2002, 07:15:29 |
Что делал, что делал, есть web-сервер, на MS SQL 7.0, чтобы обезопасить себя взял книгу Администрирование SQL 7.0 и по книге поставил архивирование, бакапы и т.д. на все базы, время установил ночью и всё. Может я что переборщил? Подскажите пожалуйста. ... |
| 08.05.2002, 08:09:56 |
Filat, исключите из плана обслуживания базы master и msdb. Если нужны и для них бэкапы, то создайте отдельный план, указав на второй страничке визарда ALL SYSTEM DATABASES. Причем, повторяю, для плана обслуживания баз master и msdb нужно устанавливать только полный бэкап БД (full database backup) и не надо включать бэкап логов для этих баз. Плюс их еще не плохо бы развести по времени. ... |
| 08.05.2002, 09:42:16 |
start [/forum/search_topic.php?author=Giperion&author_mode=last_topics&do_search=1]: |
36ms |
40ms |
| others: | 1096ms |
| total: | 1237ms |
