Как подключиться к серверу из виндового PHP?
Как подключиться к серверу из виндового PHP? ... |
| 23.08.2002, 13:51:43 |
mssql_connect ... |
| 23.08.2002, 13:57:52 |
Unable to connect to server: LODRS in c:\program files\apache\htdocs\test_sql.php on line 3 подключаюсь так: $db=mssql_connect("192.168.1.1","dbname","password"); ... |
| 23.08.2002, 14:09:18 |
Если не сложно слейте пример плз ... |
| 23.08.2002, 14:11:38 |
Лично я к серверу SQL не цепляюсь, просто в PHP Manual написано : Description int mssql_connect ([string servername [, string username [, string password]]]) Returns: A positive MS SQL link identifier on success, or FALSE on error. mssql_connect() establishes a connection to a MS SQL server. The servername argument has to be a valid servername that is defined in the 'interfaces' file. In case a second call is made to mssql_connect() with the same arguments, no new link will be established, but instead, the link identifier of the already opened link will be returned. The link to the server will be closed as soon as the execution of the script ends, unless it's я цепляюсь к MySQL , если надо могу пример , но скорее всего это не то ... ... |
| 23.08.2002, 14:42:11 |
Да, это не то ... 'interfaces' - это что такое? не в курсе? ... |
| 23.08.2002, 14:44:45 |
нет не в курсе, но Вы выполнили это условие ? These functions allow you to access MS SQL Server database. The extension requires the MS SQL Client Tools to be installed on the system where PHP is installed. The Client Tools can be installed from the MS SQL Server CD or by copying ntwdblib.dll from \winnt\system32 on the server to \winnt\system32 on the PHP box. Copying ntwdblib.dll will only provide access. Configuration of the client will require installation of all the tools. The MSSQL extension is enabled by adding extension=php_mssql.dll to php.ini. ... |
| 23.08.2002, 14:49:25 |
start [/forum/topic.php?fid=46&gotonew=1&tid=1820892]: |
53ms |
39ms |
| others: | 233ms |
| total: | 369ms |
