Подскажите с триггером...
Есть 2 таблицы (лишнее поскипано): 1. Гости CREATE TABLE H_Guest ( IdGuest int IDENTITY (1, 1) NOT FOR REPLICATION NOT NULL , IdGuestGroup int NULL , NameGuest nvarchar (100) COLLATE Cyrillic_General_CI_AS NOT NULL , PaidLimit money NOT NULL CONSTRAINT DF_H_Guest_PaidLimit DEFAULT (0), CONSTRAINT PK_H_Guest PRIMARY KEY CLUSTERED (IdGuest) ON PRIMARY , CONSTRAINT FK_H_Guest_H_GuestGroup FOREIGN KEY (IdGuestGroup) REFERENCES H_GuestGroup (IdGuestGroup) ) ON PRIMARY 2. Группы гостей CREATE TABLE H_GuestGroup ( IdGuestGroup int IDENTITY (1, 1) NOT NULL , NameGroup nvarchar (80) NOT NULL , GuestCount int NOT NULL CONSTRAINT DF_H_GuestGroup_GuestCount DEFAULT (0), PaidCount int NOT NULL CONSTRAINT DF_H_GuestGroup_PaidCount DEFAULT (0), PaidLimit money NOT NULL CONSTRAINT DF_H_GuestGroup_PaidLimit DEFAULT (0), CONSTRAINT PK_H_GuestGroup PRIMARY KEY CLUSTERED (IdGuestGroup) ON PRIMARY , ) ON PRIMARY Есть триггер: CREATE TRIGGER h_Guest_IUD ON H_Guest FOR INSERT, UPDATE, DELETE AS IF NOT UPDATE (IdGuestGroup) AND NOT UPDATE (PaidLimit) RETURN DECLARE @IdGuestGroup INT DECLARE @DeltaGuest INT, @DeltaPaid INT DECLARE @PaidLimit MONEY SET @DeltaGuest = 0 SET @DeltaPaid = 0 SET @PaidLimit = 0.0 IF EXISTS (SELECT COUNT (*) FROM INSERTED) BEGIN /* новые данные */ SELECT @IdGuestGroup = i.IdGuestGroup, @DeltaGuest = CASE WHEN i.IdGuestGroup = NULL THEN 0 WHEN i.IdGuestGroup <> NULL THEN 1 END, @DeltaPaid = CASE WHEN i.PaidLimit = 0 THEN 0 WHEN i.PaidLimit <> 0 THEN 1 END, @PaidLimit = i.PaidLimit FROM INSERTED I UPDATE H_GuestGroup SET GuestCount = GuestCount + @DeltaGuest, PaidCount = PaidCount + @DeltaPaid, PaidLimit = PaidLimit + @PaidLimit WHERE IdGuestGroup = @IdGuestGroup END IF EXISTS (SELECT COUNT (*) FROM DELETED) BEGIN /* старые данные */ SELECT @IdGuestGroup = d.IdGuestGroup, @DeltaGuest = CASE WHEN d.IdGuestGroup = NULL THEN 0 WHEN d.IdGuestGroup <> NULL THEN -1 END, @DeltaPaid = CASE WHEN d.PaidLimit = 0 THEN 0 WHEN d.PaidLimit <> 0 THEN -1 END, @PaidLimit = d.PaidLimit FROM DELETED D UPDATE H_GuestGroup SET GuestCount = GuestCount + @DeltaGuest, PaidCount = PaidCount + @DeltaPaid, PaidLimit = PaidLimit - @PaidLimit WHERE IdGuestGroup = @IdGuestGroup END При попытке привязать гостя к группе выдает сообщение типа " в поле <GuestCount> добавляется значение NULL" Объясните, плииз, откуда там NULL? С уважением, Дмитрий ... |
| 01.09.2002, 19:34:02 |
start [/forum/topic.php?fid=46&gotonew=1&tid=1820693]: |
45ms |
26ms |
| others: | 206ms |
| total: | 322ms |
