DBCC SHOWCONTIG
Проверял работу команды DBCC SHOWCONTIG. Запуск на некой таблице: DBCC SHOWCONTIG scanning 'Users' table... Table: 'Users' (772197801); index ID: 1, database ID: 8 TABLE level scan performed. - Pages Scanned................................: 255 - Extents Scanned..............................: 36 - Extent Switches..............................: 252 - Avg. Pages per Extent........................: 7.1 - Scan Density [Best Count:Actual Count].......: 12.65% [32:253] - Logical Scan Fragmentation ..................: 51.76% - Extent Scan Fragmentation ...................: 97.22% - Avg. Bytes Free per Page.....................: 2609.1 - Avg. Page Density (full).....................: 67.77% DBCC execution completed. If DBCC printed error messages, contact your system administrator. Запуск на той же таблице после прогона DBCC INDEXDEFRAG: DBCC SHOWCONTIG scanning 'Users' table... Table: 'Users' (772197801); index ID: 1, database ID: 8 TABLE level scan performed. - Pages Scanned................................: 210 - Extents Scanned..............................: 31 - Extent Switches..............................: 38 - Avg. Pages per Extent........................: 6.8 - Scan Density [Best Count:Actual Count].......: 69.23% [27:39] - Logical Scan Fragmentation ..................: 3.33% - Extent Scan Fragmentation ...................: 96.77% - Avg. Bytes Free per Page.....................: 1433.3 - Avg. Page Density (full).....................: 82.29% DBCC execution completed. If DBCC printed error messages, contact your system administrator. Запуск на той же таблице после удаления и создания CLUSTERED index'а: DBCC SHOWCONTIG scanning 'Users' table... Table: 'Users' (772197801); index ID: 1, database ID: 8 TABLE level scan performed. - Pages Scanned................................: 174 - Extents Scanned..............................: 22 - Extent Switches..............................: 21 - Avg. Pages per Extent........................: 7.9 - Scan Density [Best Count:Actual Count].......: 100.00% [22:22] - Logical Scan Fragmentation ..................: 0.00% - Extent Scan Fragmentation ...................: 18.18% - Avg. Bytes Free per Page.....................: 54.8 - Avg. Page Density (full).....................: 99.32% DBCC execution completed. If DBCC printed error messages, contact your system administrator. Как видно, все в точности соответствует описанию Books Online: самый лучший эффект от пересоздания кластерного индекса. Но есть и вопрос: Extents Scanned = Actual Count + 1. Почему? ... |
| 01.10.2002, 16:17:34 |
DBCC SHOWCONTIG
Мля, ну почему мне такое не лезет в голову? ... |
| 01.10.2002, 16:26:34 |
DBCC SHOWCONTIG
не понял я чегойто Extents Scanned..............................: 22 - Scan Density [Best Count:Actual Count].......: 100.00% [22:22] из чего 22 = 22+1???? ... |
| 01.10.2002, 16:31:09 |
DBCC SHOWCONTIG
2MiCe Actual count is the actual number of extent changes. Значит, Actual count = Extent Switches = 21 Но по факту Actual count = 22 ... |
| 01.10.2002, 16:44:08 |
DBCC SHOWCONTIG
имеем 3 точки на прямой... спрашивается сколько получится отрезков? 2, а ни как не 3.... ... |
| 01.10.2002, 16:55:07 |
DBCC SHOWCONTIG
ну или имеем 10 ступенек... сколко раз нужно шагнуть если 1 растояние между ступеньками 1 шаг 2 мы стоим на первой 3 нужно остановиться на последней... ... |
| 01.10.2002, 16:57:14 |
DBCC SHOWCONTIG
Я не про то как считать, а про то, почему цифры разнятся. ... |
| 01.10.2002, 17:00:08 |
DBCC SHOWCONTIG
Может для того, чтобы избежать деления на 0 при вычислении Scan Density? ... |
| 01.10.2002, 17:03:43 |
DBCC SHOWCONTIG
ну блин.... имеем 22 экстента... переключений между ними при сканировании в идельном случае будет 21.... и никак иначе.... ... |
| 01.10.2002, 17:28:01 |
DBCC SHOWCONTIG
Я понимаю, что число переключений между n экстентами в идеальном случае будет n-1. Только в данном случае это тоже не факт - экстенты могут быть "перемешаны" по страницам. Меня это не интересует. Меня интересует, почему разнятся значения Actual count и Extent Switches. Вроде же сказано, что Actual count НЕ есть число экстентов, а есть число переключений... ... |
| 01.10.2002, 17:37:02 |
DBCC SHOWCONTIG
вообщето.... extent changes != Extent Switches ... |
| 01.10.2002, 17:57:02 |
DBCC SHOWCONTIG
Вот-вот. Я и жду объяснения - в чем различие. ... |
| 01.10.2002, 18:01:10 |
DBCC SHOWCONTIG
Actual count is the actual number of extent changes. Actual count это реальное количество пройденных экстентов..... в идеальном случае это и есть физическое количество экстэнтов.... допустим у нас есть только 2 экстэнта.... у нас есть 3 строки 1 строка в 1 экст. 2 строка во 2 экст. 3 строка опять в 1 экст.. при сканировании мы пройдем 3 экстента в такой последовательности 1-2-1 Extents Scanned -2 Extent Switches -2 Actual Count -3 ... |
| 01.10.2002, 18:13:24 |
DBCC SHOWCONTIG
Извините, не убедили. "Extent change" И "extent" - не одно и то же. Кроме того, в Inside SQL Server 2000 нашел это: Alternatively, you can use the value called Scan Density, which is computed by dividing the optimum number of extent switches by the actual number of extent switches. Прямо не знаю... ... |
| 01.10.2002, 18:18:33 |
DBCC SHOWCONTIG
попробую я положи 22 спичечных коробка...каждый коробок - экстент поставь палец на первый..и начни переходить на следующий..сколько будет переходов? 21 :) т.е. коробок - excent scanned extent switch - движение пальца ... |
| 01.10.2002, 18:42:54 |
DBCC SHOWCONTIG
Ладно, вопрос снят. Недоросли еще. ... |
| 01.10.2002, 18:51:33 |
DBCC SHOWCONTIG
-Average number of bytes free on each page (Avg. Bytes Free per Page) -Number of pages accessed (Pages scanned) -Number of extents accessed (Extents scanned) -Number of times a page had a lower page number than the previous page in the scan (This value for Out of order pages is not displayed, but it is used for additional computations.) -Number of times a page in the scan was on a different extent than the previous page in the scan (Extent Switches) ... |
| 01.10.2002, 19:07:41 |
start [/forum/topic.php?fid=46&gotonew=1&tid=1819930]: |
41ms |
49ms |
| others: | 190ms |
| total: | 321ms |
