Временные таблицы
Добрый день Если Вас не затруднит мог бы ктонибудь ответить на следующие вопросы: Как задать временные таблицы глобальные и локальные ? Кокой срок жизни у локальных таблиц ? Какой срок жизни у глобальных таблиц ? ... |
| 03.10.2002, 16:29:41 |
Временные таблицы
Book On Line topic Temporary Tables Creating and Modifying a Table After you have designed the database , the tables that will store the data in the database can be created. The data is usually stored in permanent tables. Tables are stored in the database files until they are deleted and are available to any user who has the appropriate permissions. Temporary Tables You can also create temporary tables. Temporary tables are similar to permanent tables, except temporary tables are stored in tempdb and are deleted automatically when no longer in use. The two types of temporary tables, local and global, differ from each other in their names, their visibility, and their availability. Local temporary tables have a single number sign (#) as the first character of their names; they are visible only to the current connection for the user; and they are deleted when the user disconnects from instances of Microsoft® SQL Server™ 2000. Global temporary tables have two number signs (##) as the first characters of their names; they are visible to any user after they are created; and they are deleted when all users referencing the table disconnect from SQL Server. For example, if you create a table named employees, the table can be used by any person who has the security permissions in the database to use it, until the table is deleted. If you create a local temporary table named #employees, you are the only person who can work with the table, and it is deleted when you disconnect. If you create a global temporary table named ##employees, any user in the database can work with this table. If no other user works with this table after you create it, the table is deleted when you disconnect. If another user works with the table after you create it, SQL Server deletes it when both of you disconnect. ... |
| 03.10.2002, 16:40:27 |
start [/forum/topic.php?fid=46&gotonew=1&tid=1819884]: |
43ms |
36ms |
| others: | 252ms |
| total: | 380ms |
