Tut Guru est'?
Using integrated security for SQL 2000 on Windows 2000, I have established several requested login groups which can access the databases. I can connect to the SQL Servers using trusted connection , is there a way to see which SQLServer group my current login is coming through ? Thanks ... |
| 09.10.2002, 15:33:50 |
Tut Guru est'?
And if this login is member of several groups? ... |
| 09.10.2002, 15:43:45 |
Tut Guru est'?
may be is_member()...? ... |
| 09.10.2002, 15:46:01 |
Tut Guru est'?
May be this code help you: Код: plaintext 1. 2. ... |
| 09.10.2002, 15:51:31 |
Tut Guru est'?
Your reference does not work. ... |
| 09.10.2002, 16:04:15 |
Tut Guru est'?
select s.name from sysmembers as m inner join sysusers as s on s.uid=m.groupuid where m.memberuid=user_id() It does not help. But is_member()... It's not what i want but I can solve my problem using it. Thanks everybody. ... |
| 09.10.2002, 16:21:56 |
Tut Guru est'?
Код: plaintext 1. 2. 3. ... |
| 09.10.2002, 16:33:29 |
Tut Guru est'?
Код: plaintext ... |
| 09.10.2002, 16:35:14 |
start [/forum/topic.php?fid=46&gotonew=1&tid=1819735]: |
47ms |
25ms |
| others: | 192ms |
| total: | 295ms |
