Ошибка при запуске DBCC CHECKDB
После проверки пишет, что найдено 14 ошибок в базе. Вот листинг проверки с ошибками: Server: Msg 2535, Level 16, State 1, Line 0 Table Corrupt: Page (1:229114) is allocated to object ID 1208091790, index ID 0, not to object ID 96, index ID 0 found in page header. Server: Msg 8909, Level 16, State 1, Line 0 Table Corrupt: Object ID 96, index ID 0, page ID (1:229114). The PageId in the page header = (0:0). Server: Msg 2535, Level 16, State 1, Line 0 Table Corrupt: Page (1:229113) is allocated to object ID 1208091790, index ID 0, not to object ID 264, index ID 0 found in page header. Server: Msg 8909, Level 16, State 1, Line 0 Table Corrupt: Object ID 264, index ID 0, page ID (1:229113). The PageId in the page header = (0:0). Server: Msg 2535, Level 16, State 1, Line 0 Table Corrupt: Page (1:229116) is allocated to object ID 1208091790, index ID 0, not to object ID 560, index ID 0 found in page header. Server: Msg 8909, Level 16, State 1, Line 0 Table Corrupt: Object ID 560, index ID 0, page ID (1:229116). The PageId in the page header = (0:0). Server: Msg 2535, Level 16, State 1, Line 0 Table Corrupt: Page (1:229115) is allocated to object ID 1208091790, index ID 0, not to object ID 1008, index ID 0 found in page header. Server: Msg 8909, Level 16, State 1, Line 0 Table Corrupt: Object ID 1008, index ID 0, page ID (1:229115). The PageId in the page header = (0:0). CHECKDB found 0 allocation errors and 14 consistency errors in database 'td'. repair_allow_data_loss is the minimum repair level for the errors found by DBCC CHECKDB (td ). DBCC execution completed. If DBCC printed error messages, contact your system administrator. ... |
| 09.10.2002, 16:31:43 |
Сочувтсвую. В чем вопрос? ... |
| 09.10.2002, 16:33:33 |
Извиняюсь. Как это дело исправить? ... |
| 09.10.2002, 16:40:53 |
Сначала сделать бэкап, потом то предлагает - DBCC CHECKDB с опцией repair_allow_data_loss ... |
| 09.10.2002, 16:45:12 |
А Вы не могли бы привести синтаксис включения этой опции? ... |
| 09.10.2002, 17:01:22 |
Код: plaintext 1. 2. 3. 4. 5. 6. 7. 8. 9. 10. 11. 12. 13. 14. См. Books Online ... |
| 09.10.2002, 17:10:18 |
Я это тоже в BOL нашел. Как я понимаю, команда будет выглядеть вот так: DBCC CHECKDB ('имя базы', REPAIR_ALLOW_DATA_LOSS) ???? ... |
| 09.10.2002, 17:18:23 |
Да, так. Пример: Код: plaintext 1. 2. 3. 4. 5. 6. ... |
| 09.10.2002, 17:29:29 |
Спасибо. ... |
| 09.10.2002, 17:31:58 |
А почему бы вначале REPAIR_FAST не попробовать, как там рекомендуется? ... |
| 09.10.2002, 18:28:03 |
start [/forum/topic.php?fid=46&gotonew=1&tid=1819732]: |
40ms |
29ms |
| others: | 197ms |
| total: | 297ms |
