Server collation SQL_Latin1_General a нужен Cyrillic_Ge.. как поменять не знаю
help me please! ... |
| 11.10.2002, 09:07:56 |
какой SQL?... 7 2k? ... |
| 11.10.2002, 09:58:24 |
| 11.10.2002, 09:58:39 |
покоже на 2k наверно rebuild master или server reinstall ... |
| 11.10.2002, 10:04:04 |
Make sure you have all of the information or scripts needed to re-create your user databases and all of the objects in them. Export all of your data using a tool such as bulk copy. Drop all of the user databases. Rebuild the master database specifying the new collation. Create all of the databases and all of the objects in them. Import all of your data. Note Instead of changing the default collation of an instance of SQL Server 2000, you can specify a default collation for each new database you create. А действительно collation сервера менять надо? Базы недостаточно? ... |
| 11.10.2002, 10:29:48 |
а если база уже есть? тады увы ... |
| 11.10.2002, 10:34:51 |
start [/forum/topic.php?fid=46&gotonew=1&tid=1819694]: |
53ms |
40ms |
| others: | 200ms |
| total: | 338ms |
