How to find the hole - TSQL
How to find the hole in the PK field of a table. for example : 1,2,4 = > the first vacant place is 3 How to find this value with TSQL ? Regards, Snark ... |
| 19.10.2002, 23:33:02 |
Try this Код: plaintext 1. 2. 3. 4. 5. 6. 7. 8. 9. 10. 11. 12. 13. 14. 15. 16. 17. 18. 19. 20. 21. 22. 23. 24. 25. 26. 27. ... |
| 20.10.2002, 00:00:01 |
Тута ... |
| 20.10.2002, 00:10:58 |
Пока я лазал по поиску, Glory ответ написал ... |
| 20.10.2002, 00:12:22 |
2Cat2 Тож не спится ? ... |
| 20.10.2002, 00:26:55 |
start [/forum/topic.php?fid=46&gotonew=1&tid=1819471]: |
40ms |
57ms |
| others: | 215ms |
| total: | 374ms |
