NOT FOR REPLICATION
It is strongly recommendeds that all replicated IDENTITY columns use the NOT FOR REPLICATION option. When automatic identity range management is enabled for an article, SQL Server automatically adds the NOT FOR REPLICATION option to the IDENTITY column. The following published tables, for which automatic identity range management has not been enabled, contain IDENTITY columns without the NOT FOR REPLICATION option: [dbo].[cities] ............ ............ ............ кто знает как прально кто что порекомендует ... |
| 22.10.2002, 21:07:01 |
start [/forum/topic.php?fid=46&gotonew=1&tid=1819403]: |
38ms |
39ms |
| others: | 220ms |
| total: | 335ms |
