Права на restore
Подскажите,пожалуйста У пользователя есть роль Backup_operator. Для того, чтобы он мог восстановить базу, он должен быть обязательно членом ролей: dbowner,sysadmin,dbcreator? Нельзя как-то обойти, т.е. прав по минимуму ... |
| 14.11.2002, 13:26:21 |
Права на restore
BOL: Permissions If the database being restored does not exist, the user must have CREATE DATABASE permissions to be able to execute RESTORE. If the database exists, RESTORE permissions default to members of the sysadmin and dbcreator fixed server roles and the owner (dbo) of the database. RESTORE permissions are given to roles in which membership information is always readily available to the server. Because fixed database role membership can be checked only when the database is accessible and undamaged, which is not always the case when RESTORE is executed, members of the db_owner fixed database role do not have RESTORE permissions. In addition, the user may specify passwords for a media set, a backup set, or both. When a password is defined on a media set, it is not enough that a user is a member of appropriate fixed server and database roles to perform a backup. The user also must supply the media password to perform these operations. Similarly, RESTORE is not allowed unless the correct media password and backup set password are specified in the restore command. Defining passwords for backup sets and media sets is an optional feature in the BACKUP statement. The passwords will prevent unauthorized restore operations and unauthorized appends of backup sets to media using SQL Server 2000 tools, but passwords do not prevent overwrite of media with the FORMAT option. Thus, although the use of passwords can help protect the contents of media from unauthorized access using SQL Server tools, passwords do not protect contents from being destroyed. Passwords do not fully prevent unauthorized access to the contents of the media because the data in the backup sets is not encrypted and could theoretically be examined by programs specifically created for this purpose. For situations where security is crucial, it is important to prevent access to the media by unauthorized individuals. It is an error to specify a password if none is defined. ... |
| 14.11.2002, 13:40:19 |
start [/forum/topic.php?fid=46&gotonew=1&tid=1818802]: |
56ms |
45ms |
| others: | 196ms |
| total: | 345ms |
