Kak obedinit' neskol'ko xml-potokv v odin?
Est' dve SP, obe vozvrachaut xml-potoki (select .... for xml auto), kak mochno vupolnit' ih v tret'ei SP, obedinit' resultatu i vernut'? ... |
| 15.11.2002, 11:03:50 |
Никак "FOR XML cannot be used in a selection that requires further processing in a stored procedure. Generally, FOR XML cannot be used for any selections that do not produce direct output to the Microsoft® SQL Server™ 2000 client." ... |
| 15.11.2002, 12:17:13 |
start [/forum/topic.php?fid=46&gotonew=1&tid=1818786]: |
227ms |
25ms |
| others: | 192ms |
| total: | 481ms |
