Перенос Tempdb на другой диск
Подскажите как перенести Tempdb на другой диск не создовая новую группу файлов ... |
| 18.11.2002, 19:29:08 |
Moving tempdb To change the physical location of the tempdb database: Alter the tempdb database, using the ALTER DATABASE statement and MODIFY FILE clause, to change the physical file names of each file in tempdb to reference the new physical location, such as the new disk. Stop and restart SQL Server. Delete the old tempdb database files from the original location. ... |
| 19.11.2002, 09:08:36 |
start [/forum/topic.php?fid=46&gotonew=1&tid=1818708]: |
65ms |
57ms |
| others: | 233ms |
| total: | 421ms |
