DBCC checktable - интерпретация результата
DBCC checktable выдает следующее: Server: Msg 8934, Level 16, State 3, Line 1 Table error: Object ID 316788436, index ID 1. The high key value on page (1:1136292) (level 0) is not less than the low key value in the parent (0:1), slot 0 of the next page (4:1274656). Server: Msg 8978, Level 16, State 1, Line 1 Table error: Object ID 316788436, index ID 1. Page (1:1136292) is missing a reference from previous page (1:1121527). Possible chain linkage problem. Server: Msg 8935, Level 16, State 1, Line 1 Table error: Object ID 316788436, index ID 1. The previous link (1:1121527) on page (4:1274656) does not match the previous page (1:1136292) that the parent (4:1274654), slot 11 expects for this page. Server: Msg 8936, Level 16, State 1, Line 1 Table error: Object ID 316788436, index ID 1. B-tree chain linkage mismatch. (1:1136292)->next = (4:1274656), but (4:1274656)->Prev = (1:1121527). Server: Msg 8935, Level 16, State 1, Line 1 Table error: Object ID 316788436, index ID 1. The previous link (4:1274656) on page (4:1274657) does not match the previous page (4:1303983) that the parent (4:1274654), slot 13 expects for this page. Server: Msg 8936, Level 16, State 1, Line 1 Table error: Object ID 316788436, index ID 1. B-tree chain linkage mismatch. (4:1303983)->next = (4:1274657), but (4:1274657)->Prev = (4:1274656). Server: Msg 8978, Level 16, State 1, Line 1 Table error: Object ID 316788436, index ID 1. Page (4:1303640) is missing a reference from previous page (4:1274661). Possible chain linkage problem. Server: Msg 8934, Level 16, State 1, Line 1 Table error: Object ID 316788436, index ID 1. The high key value on page (4:1303983) (level 0) is not less than the low key value in the parent (0:1), slot 0 of the next page (4:1274657). Server: Msg 8978, Level 16, State 1, Line 1 Table error: Object ID 316788436, index ID 1. Page (4:1303983) is missing a reference from previous page (4:1274656). Possible chain linkage problem. есть соображения, что может привести к подобного рода ошибкам? ... |
| 21.11.2002, 11:55:33 |
Например, при неисправном диске, несиправном контроллере диска, неправильных драйверах к контроллеру диска, .... ... |
| 21.11.2002, 14:04:32 |
А могут ли причиной проблемы быть не проблемы железа? Дополнительная информация к размышлению :) 1 "Казус" случается периодически. 2 Всегда с одной и той же таблицей. Специфика таблицы - интенсивный характер записи в неё 3 Проявляется возникновением ошибки 601. Как правило, таблица читаема кроме последних внесенных позиций. dbcc opentran не выдаёт открытых транзакций. 4 После отключения всех пользователей ошибка НЕ пропадает. В 80% случаях приходится перезагружать sql server и application serverа, 18% - помогала опция REPAIR_* для dbcc checktable. А один раз возникла ситуация, за оглашение которой меня замечательно попинали на форуме sql.ru - дубли в таблице с первичным ключом. Пришлось удалит ь ключ, удалить дубли, заново создать ключ. 5 Особенность приложений - активное использование собственных буферов с целью осуществления отложенного сохранения. ... |
| 22.11.2002, 07:21:43 |
1. Проверьте физическое состояние диска(ов) 2. Проверьте правильность установки драйверов для контроллера диска. 3. Отключите кэширование в контроллере диска. 4. Установите torn page detection в свойствах базы. А "После отключения всех пользователей" остаются ли активные транзакции ? ... |
| 22.11.2002, 11:57:32 |
start [/forum/topic.php?fid=46&gotonew=1&tid=1818587]: |
41ms |
37ms |
| others: | 224ms |
| total: | 348ms |
