The column cannot be processed because more than one code page
Пытаюсь с помощью мастера импорта-экспорта залить данные с удаленного сервака в свою пустую только что созданную базу. Делаю все что можно по умолчанию. На этапе Validating идет ошибка. Репорт выдает такую строчку. Никакого SSIS я не создавал. Что делать? ... |
| 07.07.2011, 15:21 |
Для начала опубликовать нормально полное сообщение об ошибке Потом - версию серверов ... |
| 07.07.2011, 15:27 |
Ниже отчет об ошибке: Operation stopped... - Initializing Data Flow Task (Success) - Initializing Connections (Success) - Setting SQL Command (Success) - Setting Source Connection (Success) - Setting Destination Connection (Success) - Validating (Error) Messages * Error 0xc02020f4: Data Flow Task 2: The column "XMLdoc" cannot be processed because more than one code page (1252 and 1251) are specified for it. (SQL Server Import and Export Wizard) * Error 0xc02020f4: Data Flow Task 2: The column "message" cannot be processed because more than one code page (1252 and 1251) are specified for it. (SQL Server Import and Export Wizard) * Error 0xc004706b: Data Flow Task 2: "component "Destination 6 - Document" (125)" failed validation and returned validation status "VS_ISBROKEN". (SQL Server Import and Export Wizard) * Error 0xc004700c: Data Flow Task 2: One or more component failed validation. (SQL Server Import and Export Wizard) * Error 0xc0024107: Data Flow Task 2: There were errors during task validation. (SQL Server Import and Export Wizard) - Prepare for Execute (Stopped) - Pre-execute (Stopped) - Executing (Success) - Copying to [dbo].[a_branches] (Stopped) - Copying to [dbo].[a_nodes] (Stopped) - Copying to [dbo].[a_sources] (Stopped) - Copying to [dbo].[a_supplypoints] (Stopped) - Copying to [dbo].[a_weather] (Stopped) - Copying to [dbo].[d_raslog] (Stopped) - Copying to [dbo].[Document] (Stopped) - Copying to [dbo].[Document_aiiskue] (Stopped) - Copying to [dbo].[DocumentsState] (Stopped) - Copying to [dbo].[DocumentTest] (Stopped) - Copying to [dbo].[EventCategory] (Stopped) - Copying to [dbo].[EventsJournal] (Stopped) - Copying to [dbo].[Job] (Stopped) - Copying to [dbo].[NLoadedEMail] (Stopped) - Copying to [dbo].[Regex] (Stopped) - Copying to [dbo].[RLoadedEMail] (Stopped) - Copying to [dbo].[Sources] (Stopped) - Copying to [dbo].[sysdiagrams] (Stopped) - Copying to [dbo].[Tasks] (Stopped) - Copying to [dbo].[ULoadedEMail] (Stopped) - Copying to [dbo].[Validators] (Stopped) - Copying to [dbo].[XSLT] (Stopped) - Copying to [dbo].[z_objects] (Stopped) - Copying to [dbo].[z_reports] (Stopped) - Post-execute (Stopped) Версия SQL Server 2008 R2 Enterprise. ... |
| 07.07.2011, 15:34 |
поставить true на AlwaysUseDefaultCodePage ... |
| 07.07.2011, 16:07 |
Проблему-то я решил, указав создать новую базу для экспорта вместо существующей, но хочется понять причину на будущее. Вдруг придется импортировать в четко определенную - а тут такая подстава. ... |
| 07.07.2011, 16:07 |
EvAlexпоставить true на AlwaysUseDefaultCodePage Где поставить-то? В визарде импорта-экспорта при таскс\импорт такой опции нет. ... |
| 07.07.2011, 16:11 |
Просто это на источнике устанавливается, а к нему доступ я не имею. ... |
| 07.07.2011, 16:14 |
Привет всем, у меня возникает та же ошибка - "The column "" cannot be processed because more than one code page (1252 and 1250) are specified for it". Уже давно поставил AlwaysUseDefaultCodePage и указал 1250, в целевой базе данных везде стоит Collation SQL_Latin1_General_CP1250_CI_AS, что отвечает 1250. При запуске SSIS Package в деталях ошибки показывает, что пэкедж так же был настроен DefaulCodePage 1250... Сталкивался кто с таким? Уже неделю голову ломаю над этим... Спасибо! ... |
| 26.11.2018, 17:35 |
start [/forum/topic.php?fid=46&gotonew=1&tid=1688709]: |
23ms |
221ms |
66ms |
| others: | 245ms |
| total: | 604ms |
