Не удается создать индекс с помощью дизайнера - "... set property PartitionScheme."
Всем привет, не удается на таблице создать индекс с помощью дизайнера. Вылетает вот такая ошибка: текст ошибки=================================== Exception has been thrown by the target of an invocation. (mscorlib) ------------------------------ Program Location: at System.RuntimeMethodHandle.InvokeMethod(Object target, Object[] arguments, Signature sig, Boolean constructor) at System.Reflection.RuntimeMethodInfo.UnsafeInvokeInternal(Object obj, Object[] parameters, Object[] arguments) at System.Reflection.RuntimeMethodInfo.Invoke(Object obj, BindingFlags invokeAttr, Binder binder, Object[] parameters, CultureInfo culture) at System.Reflection.RuntimePropertyInfo.GetValue(Object obj, BindingFlags invokeAttr, Binder binder, Object[] index, CultureInfo culture) at System.Reflection.RuntimePropertyInfo.GetValue(Object obj, Object[] index) at Microsoft.SqlServer.Management.Sdk.Sfc.SfcObjectExtender`1.ReflectedProperty.get_Value() at Microsoft.SqlServer.Management.Data.DataBus.DataBusItem..ctor(DataBus dataBus, ISfcProperty property) at Microsoft.SqlServer.Management.Data.DataBus.DataBusItem..ctor(DataBus dataBus, ISfcProperty property, ISfcPropertyProvider provider) at Microsoft.SqlServer.Management.Data.DataBus.Add(ISfcProperty property, ISfcPropertyProvider propertyProvider) at Microsoft.SqlServer.Management.Data.DataBus.Add(ISfcPropertyProvider propertyProvider) at Microsoft.SqlServer.Management.TaskForms.SmoTaskFormComponent`1.OnInitialize() at Microsoft.SqlServer.Management.RelationalEngineTasks.IndexTaskFormComponent.OnInitialize() at Microsoft.SqlServer.Management.TaskForms.SmoTaskFormComponent`1.Initialize(ITaskManager taskManager, IPropertyDictionary properties) at Microsoft.SqlServer.Management.TaskForms.TaskManager.InitializeTaskFormComponent(Object component, ITaskFormComponentInfo info) at Microsoft.SqlServer.Management.TaskForms.TaskFormManager.InitializeTaskFormComponent(Object component, ITaskFormComponentInfo info) at Microsoft.SqlServer.Management.TaskForms.TaskManager.InitializeTaskFormComponents(IList`1 taskFromComponentsInfo) at Microsoft.SqlServer.Management.TaskForms.TaskFormManager.InitializeTaskFormComponents(IList`1 taskFromComponentsInfo) at Microsoft.SqlServer.Management.TaskForms.TaskManager.Initialize(String moniker, IContext context, IList`1 taskFromComponents) at Microsoft.SqlServer.Management.TaskForms.TaskFormManager.Initialize(String moniker, IContext context, ITaskFormInfo taskFormInfo) at Microsoft.SqlServer.Management.TaskFormFactoryService.CreateTaskFormInstance(String taskFormMoniker, IContext context) at Microsoft.SqlServer.Management.ActionHandlers.ShowTaskUIDialogActionHandler.RunTaskForm(IContext context) at Microsoft.SqlServer.Management.ActionHandlers.DialogBasedActionHandler.RunTaskFormThread(Object contextObject) =================================== To accomplish this action, set property PartitionScheme. (Microsoft.SqlServer.Smo) ------------------------------ For help, click: http://go.microsoft.com/fwlink?ProdName=Microsoft SQL Server&ProdVer=15.0.18040.0 ((SSMS_Rel).180920-2155)&EvtSrc=Microsoft.SqlServer.Management.Smo.ExceptionTemplates.PropertyNotSetExceptionText&LinkId=20476 ------------------------------ Program Location: at Microsoft.SqlServer.Management.Smo.SqlSmoObject.OnPropertyMissing(String propname, Boolean useDefaultValue) at Microsoft.SqlServer.Management.Smo.PropertyCollection.RetrieveProperty(Int32 index, Boolean useDefaultOnMissingValue) at Microsoft.SqlServer.Management.Smo.PropertyCollection.GetValueWithNullReplacement(String propertyName, Boolean throwOnNullValue, Boolean useDefaultOnMissingValue) at Microsoft.SqlServer.Management.Smo.Index.get_PartitionScheme() at Microsoft.SqlServer.Management.Smo.IndexExtender.get_PartitionFunctionDataType() С помощью кода индекс создается без проблем. Кто-нибудь сталкивался? ... |
| 07.12.2018, 14:38 |
User2155, студия криво стоит (каких нить бибилиотек не хватает) ... |
| 07.12.2018, 14:47 |
start [/forum/topic.php?fid=46&gotonew=1&tid=1688644]: |
182ms |
59ms |
| others: | 252ms |
| total: | 554ms |
