изменить коллейшн БД
Здравствуйте Господа, пытаюсь изменить коллейшн у базы Код: sql 1. 2. 3. Получаю два десятка таких ошибок Msg 5075, Level 16, State 1, Line 3 The object 'XXXXXXXXXXXX' is dependent on database collation. The database collation cannot be changed if a schema-bound object depends on it. Remove the dependencies on the database collation and then retry the operation. Что можно сделать в данной ситуации? Также получаю FILESTREAM DIRECTORY_NAME 'XXXX' attempting to be set on database 'XXX' is not unique in this SQL Server instance. Provide a unique value for the database option FILESTREAM DIRECTORY_NAME to enable non-transacted access. Версия Microsoft SQL Server 2016 (SP1-CU2) (KB4013106) - 13.0.4422.0 (X64) Mar 6 2017 14:18:16 Copyright (c) Microsoft Corporation Enterprise Edition (64-bit) on Windows Server 2016 Datacenter 6.3 <X64> (Build 14393: ) (Hypervisor) ... |
| 07.03.2019, 17:15 |
https://docs.microsoft.com/en-us/sql/t-sql/statements/alter-database-transact-sql?view=sql-server-2017 Раздел "Changing the Database Collation" ... |
| 07.03.2019, 17:36 |
start [/forum/topic.php?fid=46&gotonew=1&tid=1688162]: |
184ms |
48ms |
| others: | 214ms |
| total: | 490ms |
