syspolicy_purge_history
Cоздавал jobs для автоматического бэкапа базы и нечайно удалил syspolicy_purge_history, подскажите плиз что это за задача? ... |
| 15.10.2020, 06:44 |
https://www.google.com/search?q=syspolicy_purge_history The SYSPOLICY_PURGE_HISTORY is a built-in SQL Server Agent Job which is configured to run once a day at 2 AM. When SYSPOLICY_PURGE_HISTORY SQL Server Agent Job is executed it will remove records from the above tables, except for the retention period records. ... |
| 15.10.2020, 07:00 |
start [/forum/topic.php?fid=46&gotonew=1&tid=1685518]: |
131ms |
32ms |
| others: | 235ms |
| total: | 434ms |
