Ограничение по дате с участием @ReportDate
Пытаюсь через dateadd и @ReportDate сделать ограничение по месяцу вместо использования appl_month. Подскажите как правильно это сделать. Примерный запрос: DECLARE @ReportDate date SET @ReportDate = '01.09.2020' select appl_month , (sum(case when financed = 1 and appl_month = '2020-07' then app_PS_2mob end) / sum(case when financed = 1 and appl_month = '2020-07' then cash_to_client end)) / cast((sum(case when financed = 1 and appl_month = '2020-07' then app_PS_1mob end) / sum(case when financed = 1 and appl_month = '2020-07' then cash_to_client end)) as float) as Рои2наРои1_07 , (sum(case when financed = 1 and appl_month = '2020-06' then app_PS_2mob end) / sum(case when financed = 1 and appl_month = '2020-06' then cash_to_client end)) / cast((sum(case when financed = 1 and appl_month = '2020-06' then app_PS_1mob end) / sum(case when financed = 1 and appl_month = '2020-06' then cash_to_client end)) as float) as Рои2наРои1_06 from DWH where date_time >= '01-01-2020' and date_time <='12-31-2020' group by appl_month order by appl_month ... |
| 16.03.2021, 18:45:28 |
start [/forum/topic.php?fid=46&gotonew=1&tid=1684947]: |
171ms |
| others: | 181ms |
| total: | 406ms |
