Импорт geoJSON в MSSQL
1) Данные DECLARE @JSON NVARCHAR(MAX) = '[{"type":"CIRCLE","id":null,"radius":2653.523472444495,"geometry":[32.37607276521905,50.89607968139649]}, {"type":"POLYLINE","id":null,"geometry":[[32.384191106549274,51.02242245483399],[32.33721060680366,50.95410122680665],[32.298912157759965,50.94277157592774]]}, {"type":"POLYGON","id":null,"geometry":[[[32.38100184516367,51.06739773559571],[32.34562248984498,51.025855682373056],[32.298912157759965,51.040618560791025], [32.2986219561919,51.08284725952149],[32.362733906763,51.158721588134775],[32.39143900915657,51.09658016967774]]]}, {"type":"RECTANGLE","id":null,"geometry":[[32.30877845819,50.85625424194337],[32.3360502857075,50.91736569213868]]}, {"type":"MARKER","id":null,"geometry":[32.36940358204207,50.95101132202149]}]'; 2) Хочу впихнуть в таблицу (type (varchar(10), id int, radius float, geometry nvarchar(max)) 3) Запрос: SELECT * FROM openjson(@JSON) with ( [type] varchar(10) '$.type', [id] int '$.id', [radius] float '$.radius', [geometry] varchar(max)'$.geometry' ) 4) Результат: type id radius geometry CIRCLE NULL 2653.52347244449 NULL POLYLINE NULL NULL NULL POLYGON NULL NULL NULL RECTANGLE NULL NULL NULL MARKER NULL NULL NULL 5) Как получить 'geometry'? ... |
| 13.05.2021, 13:58:21 |
Влади, [geometry] nvarchar(max) as json ? ... |
| 13.05.2021, 15:16:35 |
start [/forum/topic.php?fid=46&gotonew=1&tid=1684719]: |
74ms |
39ms |
| others: | 193ms |
| total: | 363ms |
