Files properties
Gde mozhno naiti informaciju o FILES PROPERTIES i PATH PROPERTIES? (help uzhe smotrela) ... |
| 02.06.2002, 17:25:00 |
Files properties
GetAttr Function Returns an Integer representing the attributes of a file, directory, or folder. Syntax GetAttr(pathname) The required pathname argument is a string expression that specifies a file name. The pathname may include the directory or folder, and the drive. Return Values The value returned by GetAttr is the sum of the following attribute values: Constant Value Description vbNormal 0 Normal. vbReadOnly 1 Read-only. vbHidden 2 Hidden. vbSystem 4 System file. Not available on the Macintosh. vbDirectory 16 Directory or folder. vbArchive 32 File has changed since last backup. Not available on the Macintosh. vbAlias 64 Specified file name is an alias. Available only on the Macintosh. Note These constants are specified by Visual Basic for Applications. The names can be used anywhere in your code in place of the actual values. Remarks To determine which attributes are set, use the And operator to perform a bitwise comparison of the value returned by the GetAttr function and the value of the individual file attribute you want. If the result is not zero, that attribute is set for the named file. For example, the return value of the following And expression is zero if the Archive attribute is not set: Result = GetAttr(FName) And vbArchive A nonzero value is returned if the Archive attribute is set. более подробные данные о файлах можно получить используя функции API http://izdatel.boom.ru/api_html/index.html ... |
| 07.06.2002, 14:12:08 |
start [/forum/topic.php?fid=45&gotonew=1&tid=1683540]: |
26ms |
| others: | 197ms |
| total: | 285ms |
