Транзакции в Access ?
Возможно ли использование транзакций в Access ? Попробовал с ADO - даёт ошибку: No transaction is active. Система: win98, Access 97. MS Acsses driver v.4.00, ADO v. 2.0 , ADOR v. 2.7. CODE: Dim Con As ADODB.Connection Dim Rec As ADODB.Recordset Set Con = New ADODB.Connection Set Rec = New ADODB.Recordset Con.ConnectionString = "DSN=MyDSN" Con.Open If Con.State = adStateOpen Then Rec.Open strNewRecord, Con, adOpenDynamic, adLockPessimistic, adCmdText Else DoCmd.SetWarnings True MsgBox "Some error has occured while trying to perform the procedure. Try again later." Set Rec = Nothing Set Con = Nothing Exit Sub End If On Error GoTo transerror Con.BeginTrans ' ЗДЕСЬ ОШИБКА И УХОДИМ НА: transerror: Con.RollbackTrans ' И ПОЛУЧАЕМ ВЫШЕОПИСАННОЕ СООБЩЕНИЕ ... |
| 02.08.2002, 01:56:19 |
start [/forum/topic.php?fid=45&gotonew=1&tid=1683451]: |
62ms |
45ms |
| others: | 232ms |
| total: | 386ms |
