Проблемка, кто-нибудь help!
Есть таблицы и запросы, которые храняться в базе: SPR_BRAK_M - > таблица UCHASTKI - > таблица CONTRAKT - > таблица PROSTOY - > таблица zapr_Proiz_Uch_Contr (запрос)=SELECT CONTRAKT.Uchastok, [Q_Stankov]*[Proizvodit_hour]*[Resurs_Time] AS Proiz_Uch_Contr FROM CONTRAKT; zapr_Select_Hour_Prostoy (запрос)=SELECT PROSTOY.Uchastok, Sum(PROSTOY.Hours) AS [Sum-Hours] FROM PROSTOY WHERE (((PROSTOY.Date_) Between [p1] And [p2] )) GROUP BY PROSTOY.Uchastok; zapr_Max_Zagr (запрос)= "SELECT SPR_BRAK_M.ID, Format(((([sum-Proizvodit_hour]*[avg-Resurs_Time]+(nz([Proiz_Uch_Contr],0)*contrakt_vvod(1,0)))*(contrakt_vvod(1,1)-0.5*calc_Grafika( [p_1] , [p_2] ))-(nz([Sum-Hours],0)*[avg-Proizvodit_hour]))*Proz_Brak()/[Presch_vid_Prod])/5000,"0")*5000 AS Itog_Proizvod, Avg(UCHASTKI.Proizvodit_hour) AS [Avg-Proizvodit_hour], Sum(UCHASTKI.Proizvodit_hour) AS [Sum-Proizvodit_hour], Avg(UCHASTKI.Resurs_Time) AS [Avg-Resurs_Time], zapr_Select_Hour_Prostoy.[Sum-Hours], zapr_Proiz_Uch_Contr.Proiz_Uch_Contr, SPR_BRAK_M.Presch_vid_Prod FROM SPR_BRAK_M INNER JOIN (UCHASTKI LEFT JOIN (zapr_Select_Hour_Prostoy RIGHT JOIN zapr_Proiz_Uch_Contr ON zapr_Select_Hour_Prostoy.Uchastok = zapr_Proiz_Uch_Contr.Uchastok) ON UCHASTKI.ID_Uchastok = zapr_Proiz_Uch_Contr.Uchastok) ON SPR_BRAK_M.ID = UCHASTKI.ID_Uchastok GROUP BY SPR_BRAK_M.ID, zapr_Select_Hour_Prostoy.[Sum-Hours], zapr_Proiz_Uch_Contr.Proiz_Uch_Contr, SPR_BRAK_M.Presch_vid_Prod;" Выполняю программу для того, чтобы заполнить таблицу MAX_ZAGRUZKA на основе запроса zapr_Max_Zagr : sub ins() Dim Date_Begin As Date Dim Date_End As Date Dim qf As QueryDef Date_Begin = CDate("01.01." & Trim(Str(Year(Date)))) Date_End = DateAdd("d", -1, DateAdd("m", 1, Date_Begin)) SQL_ADD = "PARAMETERS [p1] DateTime, [p2] DateTime, [p_1] DateTime, [p_2] DateTime;" & _ "INSERT INTO MAX_ZAGRUZKA ( Uchastok, " & I & " ) " & _ "SELECT zapr_Max_Zagr.ID, zapr_Max_Zagr.Itog_Proizvod " & _ "FROM zapr_Max_Zagr ;" Set qf = Сurrentdb.CreateQueryDef("", SQL_ADD) qf.Parameters("p1") = Date_Begin qf.Parameters("p2") = Date_End qf.Parameters("p_1") = Date_Begin qf.Parameters("p_2") = Date_End qf.Execute-->Ошибка( Ошибочный Аргумент ), причем только в Access2000, а в Access97 все OK???? Я думаю что проблемма в передаваемых параметрах- [p1],[p2],[p_1],[p_2] , а как грамотно их передать, в таком случае не знаю???? qf.Close end sub ... |
| 24.02.2003, 16:57 |
start [/forum/topic.php?fid=45&gotonew=1&tid=1682243]: |
168ms |
37ms |
| others: | 210ms |
| total: | 464ms |
