Как выбрать в ListBox имена всех таблиц, начинающихся со знака '_'
subj/ ... |
| 20.04.2003, 10:40 |
Список List0 Вариант 1: ======================= Private Sub Form_Open(Cancel As Integer) Dim td As DAO.TableDef, strList As String Me!List0.RowSourceType = "Value List" strList = "" For Each td In CurrentDb.TableDefs If Left(td.Name, 1) = "_" Then strList = IIf(strList > "", strList & ";" & td.Name, td.Name) End If Next Me!List0.RowSource = strList Set td = Nothing End Sub ======================= Вариант 2: ======================= Private Sub Form_Open(Cancel As Integer) Me!List0.RowSourceType = "ListTables" End Sub Function ListTables(fld As Control, id As Variant, row As Variant, col As Variant, code As Variant) As Variant Dim ReturnVal As Variant, ctr As Container, doc As Document Dim td As DAO.TableDef Static NameObject(127) As String, Entries As Integer ReturnVal = Null Select Case code Case acLBInitialize Entries = 0 For Each td In CurrentDb.TableDefs If Left(td.Name, 1) = "_" Then NameObject(Entries) = td.Name Entries = Entries + 1 End If Next ReturnVal = Entries Case acLBOpen ReturnVal = Timer Case acLBGetRowCount ReturnVal = Entries Case acLBGetColumnCount ReturnVal = 1 Case acLBGetColumnWidth ReturnVal = -1 Case acLBGetValue ReturnVal = NameObject(row) Case acLBEnd Erase NameObject End Select ListTables = ReturnVal Set td = Nothing End Function ======================= Вариант 3: ======================= Private Sub Form_Open(Cancel As Integer) Me!List0.RowSource = "SELECT [Name] FROM MSysObjects WHERE [Type]=1 AND Left([Name],1)='_';" End Sub ======================= ... |
| 20.04.2003, 11:51 |
start [/forum/topic.php?fid=45&gotonew=1&tid=1681759]: |
168ms |
45ms |
| others: | 259ms |
| total: | 531ms |
